Cheap ways to add hp
Old Feb 16, 2009 | 01:48 PM
_firebird_'s Avatar
Car: 1988 firebird trans am
Engine: 305 fuel inject. tbi
I have a 305 fuel injection that needs some more power. Anybody have any suggestions? Planning on putting a cold air intake on. I need to make the tubing though because it sucks he air in from the top of throttle body. Anyone know how to do that too? Thanks for you help in advance!
Old Feb 16, 2009 | 01:50 PM
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
Re: Cheap ways to add hp
nitrous oxcide is the cheapest hp to $$ ratio. i highly doubt a cold air intake will make a very noticable difference.
Old Feb 17, 2009 | 12:36 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You're in the wrong forum. This "power adder" forum is for nitrous, superchargers, and turbochargers, as it says in the description.
You need to check out either the TPI or TBI forum, depending on which engine you have.
Old Feb 17, 2009 | 01:47 AM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
I had a tbi engine once, i just ordered the tbi CAI kit for the 88-98 chevy silverado. same engine, same kit.
chazman
Aug 28, 2018 03:25 PM
italiano67
Dec 11, 2016 09:21 AM
dutch930
Sep 11, 2015 06:58 AM
chazman
Aug 22, 2015 02:01 PM
sreZ28
Aug 14, 2015 07:48 PM
