Few general questions..
I got an 89 Camaro, with 2 T3/t4s on it, aready running fine and fun. Just had a few questions.
Here is a list of current mods...
Upgraded fuel system
ungranded ignition parts
water/meth injection kit
megasquirt standalone ecm
Heres my questions,
What is the max boost I can run
my turbo has an internal wastegate, and the arm seems to be adjusted, can that be used so I an turn the boost down from the standard opening 8psi?
Even tho, the wastegate is suppose to be 8psi, Im getting 9.7, is there anyway I can lower the boost?
What is something I need to look out for, if my engine is messing up? Like if Im running too much or somethings going wrong..
Thank you for any info guys
Heres my questions,
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
Re: Few general questions..
need more specs... and a picture of your setup.
motor specs?
turbo specs?
intercooled?
make the wastegate actuator longer to reduce boost pressure.
motor specs?
turbo specs?
intercooled?
Motor Specs-L98, 350 sbc, TPI. 90% stock. Only thing changed was ignition and fuel components. MSD Coil, accell HEI module,cap,rotor. Bosch spark plugs, with the 4 tips on it. Fuel-FIC 32lb injectors rated at 43psi, 255 walboro fuel pump, adjustable fuel pressure regulator.
Turbo specs- Twin, T3/T4 turbos, 50 A/R Compressor, .63 A/R turbine, 3"inlet, 2" outlet. Mounted in the engine bay on the headers.Internal wastegates, set at 8psi
Intercooler- I do have one, its like 31"x14" BUT its not installed. Currently, they are just ran into a Y pipe, then into the intake, with a water/meth injection kit. Wasnt too sure if I should install it or not. I also have a BOV right before the throttle body.
Thats really all the info I can think of, thank you for helping
Pac J
May 17, 2020 10:44 AM
1Aauto
Sponsored Vendors
Sep 13, 2017 12:58 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
