2 quick questions
Old Aug 20, 2009 | 01:13 PM
goes12s's Avatar
2 quick questions
just 2 quick questions, i have a roller 350 with 190cc aluminum heads 64cc and a victor jr intake, holley 750 carb modded for blowthrough and cr 9.2:1, building my own single turbo manifolds, and t56, mainly a drag car with some street use, and 93 octane
question 1:
what kind of cam should i go with, heads will support up yo .600 lift??i want to rev up to about 6800-7000
question 2:
how laggy will a BW s400 turbo be on this setup at around 8psi to start with?
http://cgi.ebay.com/ebaymotors/Genui...=p4506.c0.m245
thanks in advance
Old Aug 21, 2009 | 03:43 PM
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
Re: 2 quick questions
mmhmm
Old Aug 21, 2009 | 09:01 PM
goes12s's Avatar
Originally Posted by noboostnogo
mmhmm
ive spent about 2 hrs trying to find some info on turbo cams and all i got was that i want the lsa to be >112 like 114. what would be a good cam for ~500 to 600hp
and when should i expect to see boost with the s400? 3500rpms???
i would really like some advice from personal experience. thanks in advance
Old Aug 22, 2009 | 12:16 AM
Camarslow's Avatar
Car: 1984 Z28
Engine: none
Transmission: none
1. Your best bet is to call a cam company like comp, they should be able to provide the best cam selection advice anyone can give you.
2. iirc a BWs400 turbo should work fine on a 350, I've heard of others using them, please correct me if I'm mistaken.
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
