Compatability question????
Old Jan 19, 2011 | 10:10 AM
motenkjr's Avatar
Car: 1985 Camaro
Engine: 305 ci
I've read and didn't see this answered. If it has been answered and I overlooked it please point me in the right direction. I'm wondering if a 4th gen rearmount turbo system can fit our thirdgens with slight modifications? I'm about to do a ls swap and want to keep a/c so that's the reason I'm considering the rmt. Thanks in advance guys.
Old Jan 29, 2011 | 02:56 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Compatability question????
i don't see why not. i have to add though, one very important factor for an effective/efficient turbo setup is allowing as little exhaust heat as possible to dissipate before it reaches the turbo. by the time the exhaust gases reach the rear of the car it has lost much of its heat and velocity.
Old Jan 29, 2011 | 01:29 PM
joker0907's Avatar
Car: 1991 camaro rs, 2001 buick century
Engine: 305, 3.1
this can be fixed by using sized turbos and wrapping/coating the exaust all the way back!
Old Jan 29, 2011 | 01:44 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
and the kits made for rear mount take all that into account so you still get some ok boost for your coin.
only thing id "worry" about is keeping it feed with clean air [a filter under a car will get dirty fast] and making sure the oil was plumbed to it well and flowed right all the time. But Im sure they thought of that too.
Old Jan 29, 2011 | 02:13 PM
joker0907's Avatar
Engine: 305, 3.1
the sts kits from what ir ead the filter they use is just a K&n but seems to work fine the oil problem is where everyone seems to have the problems with rear mounts with the pumps going out but im sure that could be fixed easy with a seperate tank for oil in the rear instead of having to run it carlengths
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
