Fuel system for boost- Surge Tank?
Old Apr 22, 2011 | 08:51 PM
83 Crossfire TA's Avatar
Seems like everyone is either going with a lot of pump in the tank (at least a single 255 or twins), or sumping the tank and going with a big inline pump... Has anyone tried or thought about running a surge tank?
Seems like a surge tank might be a better way of doing this, use the stock intank to pump fuel into the surge tank, at no pressure it should be able to move _a lot_ of fuel, and the surge tank should give you a location that you can keep the pickup from getting uncovered better than any of the stock tanks, and should be easier to setup (packaging, plumbing, wire the pump straight off the alternator without having to run wire to the back of the car and some sort of relay setup for twin pumps...)...
Old Apr 22, 2011 | 09:25 PM
daverr's Avatar
Re: Fuel system for boost- Surge Tank?
I thought about doing the surge tank on my race car but decided not to . the surge tank would just add more clutter. Im going to mount a fuel cell in the front of the car and use a mechanical fuel pump. I have a ice water tank mounted just rear of the stock fuel tank location.
On my turbo street car i have a fuel cell mounted in the trunk and never had a problem. If your building a street car i would get a fuel cell built for your application.
Old Apr 23, 2011 | 12:13 PM
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
this is the first time ive heard of a surge tank so please excuse my ignorance but wouldnt you still need a pump or two to pressurize fuel from the surge tank to your regulator? i feel like if this is true it would be more complicated than the other setups you mentioned. Not only you have to find a place for the tank but you also have to wire in the pumps and at the end of the day you are still using your factory 20+ yr old pump
http://www.youtube.com/watch?v=jb02Hhf1Df4
Old Apr 24, 2011 | 12:12 AM
Drac0nic's Avatar
If your surge tank was large enough it may also be a nice way to mitigate "fuel slosh" issues as well. For some odd reason I'm almost thinking something like a heavily modified freon container.
Old Apr 25, 2011 | 11:09 PM
what kind of freon container?
midge54
Dec 27, 2019 04:14 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
kyleb24
Aug 15, 2015 08:24 AM
