stock 1985 tpi fuel pump question
Old May 8, 2011 | 04:56 PM
1991firebirdman's Avatar
hello everyone. can someone answer how much power a stock 305 tpi fuel pump can handle? my engine is a 425-450 hp 406 with a holley 750 dp (if that matters) i plan maybe adding a 100-125 shot of nitrous in the future and just want to see if the stocker can handle it, if not i already have a mech. fuel pump from holley thats rated at 110gph. thanks for your time
Old May 8, 2011 | 06:18 PM
ZZ3Astro's Avatar
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
Re: stock 1985 tpi fuel pump question
On my 5.7 tpi, at 9 psi I was running near 100% duty cycle with 65 lb/hr injectors using the stock pump. 9 psi on a stock psi is around 350 crank hp. I've read of people at 400 hp with stock pumps. Of course you will be stepping down to a lower fuel pressure and it becomes a question of volume. I don't think I'd risk it though, but if you do, let us know what happens
Sounds like it will be a fun car!
Old May 8, 2011 | 09:31 PM
thank you zz3astro. i'm thnking about using the stock pump to break everything in, then when i get back from basic training switching it all over to the mechanical one i have. if anyone has any thing to add please post it up! thanks
Old May 10, 2011 | 03:29 PM
Ronny's Avatar
I run a tpi pump. tbi 80 lbs injs at 20 lbs FP. my motor is about 350 hp. i run 75hp n20. last season i was seeing 11.0/1 at wot with n20 on. i believe DC was 85%
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
beachrodder
Aug 25, 2015 08:05 AM
