Running 700 hp with a 600 carb....
Old Jul 23, 2012 | 06:14 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Two years ago is the last I ran my car. My Barry Grant blowthrough carb had a stripped squirter screw so I threw on my 600 from the original 305 that I boosted. I got a kit to sleeve the squirter hole but failed due to a bent head on my uncles drill press. Irritating and completely my fault. I was about ready to sell the whole setup and go nitrous to just get a few fast runs before the motor goes in a mud truck and a 6.0 takes its place.
But then I was going over my times and I ran 10.7@127 with that little carb with tuning still far from perfect, faulty ignition box, and no meth injection. I'm wondering if I could get low 10s out of it......seems silly with such a small carb, but I only spin to 6300 rpms.
What do you guys think? How much do you think its holding me back?
383, vortech s-trim, rpm intake, 200cc heads, xr288hr
Old Jul 23, 2012 | 06:49 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Running 700 hp with a 600 carb....
Originally Posted by Batass
But then I was going over my times and I ran 10.7@127 with that little carb with tuning still far from perfect, faulty ignition box, and no meth injection. I'm wondering if I could get low 10s out of it......seems silly with such a small carb, but I only spin to 6300 rpms....
With that 127-mph trap speed you should already be in low ten second territory, what was your sixty foot during that particular run? Any pics of the current setup...?
Old Jul 23, 2012 | 07:07 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
60 was 1.631. No pics. Last one I took was four years ago.
Old Jul 23, 2012 | 07:38 PM
60 was 1.631...
Carb definitely needs to be tuned, and if you can stick the launch you'll see easy low tens...
Old Jul 24, 2012 | 10:14 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Keep in mind that with a blow through, the CFM capacity goes up with boost (as opposed to a suck through). So if you are running 7.5 psi boost, your carb has about 900cfm capacity for example.
Supercharged cars can pick up a lot of power with A/F tuning - don't be surprised if you pick up 50hp from that alone. Add in the gain from meth injection and you can probably see another 80 to 100hp if everything is right. 127mph in a 3500lb car is about 550 to 560hp, so adding 90hp to that should add another 6 or 7mph to your trap speed. No reason to think you couldn't run 10.3 with that.
Vintageracer
Jan 10, 2020 05:33 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
LT1Formula
Nov 16, 2015 01:13 PM
86IROC112
Aug 17, 2015 02:00 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
