Fuel injector selection
Old Jul 5, 2013 | 02:21 PM
Ryan Wandell's Avatar
Car: 89' RS.
Engine: Carbureted 305.
Axle/Gears: 4.56
Well I'm looking to turbo my carb'd 305 (previous LO3), It's currently got stock internals and I'm planning to keep it that way with a turbo until I get a bit more time to do a intake manifold and cam swap.
So I've got a few things down, looking to get this 62-1 series:
http://www.ebay.com/itm/godspeed-t3-62-1-turbo-charger-v2-63-trim-4-bolt-500hp-t3-Universal/290756542874?_trksid=p2045573.m2042&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D27%26meid%3D8864372657403716613%26pid%3D100033%26prg%3D1011%26rk%3D3%26sd%3D280920368766%26
I know that my engine started as TBI but was swapped to a carb, I don't know what kind of injectors they used or if they're stock. What kind of injectors would you guys recommend with this setup, and fuel pump, etc.
I'm currently using an inline electric pump rated 5.5-9 PSI, not sure on injectors but If I'm going to go this far I might as well swap those out too.
Old Jul 5, 2013 | 03:07 PM
project89's Avatar
Re: Fuel injector selection
keep it carbed and turbo it that way it will be cheaper in the long run and make mor ep ower
as far as the turbo u picked out it isnt a 62-1 u need to carefully read the auctions
T3/62-1 TURBO CHARGER .63ar( BIG SHAFT)
T3/60-1 turbo
Intake: 3 inch
Inlet: 2.5 inch
Compressor trim: .70ar
Compressor Wheel diameter: 56.83/ 74.96
Turbine Wheel diameter: 61.37 /69.86
Exhaust Trim: .63ar
Turbine flange type : T3 flange
Down pipe flange type: 4 bolt
Cooling type: oil cool only
Horsepower rating: 400-500
that is a 57mm compressor u would need two of those on a v8 specially since they have tiny t3 turbine sides , i have a pair of similar sized turbos on my iroc and they spool lightning fast
get 2 of those turbos
a single plane intake
a holley 4150 650 dp and modify it for boost
and yes u will need a much better fuel pump
Old Jul 5, 2013 | 11:53 PM
Car: 89' RS.
Axle/Gears: 4.56
What kind of fuel pump should I get?
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
