Rear mount charge pipe route question
Old Aug 7, 2013 | 02:08 PM
Blowtorch79's Avatar
Car: 1989 Formula 350
Engine: 383ci, +150hp N20
Transmission: Built 700R4
Axle/Gears: Moser 9", 3.73 Detroit locker
So I finally got my Holley HP EFI installed and the car is running smooth. I am adding an STS rear mount turbo. How are you rear mount turbo guys routing you charge pipe????
Also, anyone using the ZZ409 cam with boost? If so, how is it responding? I'm looking to run 8-10lbs.
Thanks in advance,
Jim
Old Aug 9, 2013 | 09:30 AM
Re: Rear mount charge pipe route question
No rear mount guys care to help me out????
Thanks in advance,
Jim
Old Aug 9, 2013 | 09:54 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
When i was contemplating doing my other car, i debated on running charge pipes down stock exhaust location. My twin turbo car runs dual 3" exhaust down stock location so you can fit a single exhaust plus charge pipe all the way up to front subframe. Only issue is once you get towards where the y pipe comes down around behind the passenger front tire well, you wont have room for the charge pipe, so it would have to dip under trans xmember area/subframes by trans bellhousing. That can get tricky for clearance purposes
If you had shorty headers of some sort or manifolds and had a ypipe made where it was able to connect before coming around behind the passengerfront tire well, then you may fit charge pipe all the way up through there.
So i was also thinking of running down driveshaft tunnel along fuel line routing side. I was gonna run 2.5" pipe for this mild 500 hp idea. Could snake it through trans xmember and come up under passenger side header i think. It would be tight depending what your exhaust manifolds look like. Long tubes no way. Shorties positioned right may have a chance
Old Aug 9, 2013 | 10:06 AM
Thanks. I am running a 2.5" charge pipe. I believe I have it figured out. Meeting with my fabricator tomorrow morning to discuss my idea(s). I'll post up some pictures when we get it nailed down. I really wanted to see some pictures of what guys have done. Haven't seen a single picture of a rear mount that shows the install from front to back. (on a 3rd gen)
Old Aug 9, 2013 | 10:44 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Honestly there isn't many guys that run this setup on here, if any... Its to bad too cause I think its not a bad setup for what it is.
This is the only pic I could find that I had saved on my computer but might give you some ideas, not sure who's car it was.
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
redmaroz
Aug 16, 2015 11:40 PM
