Blowthrough holley
Old Oct 7, 2013 | 02:03 PM
cumminsN14's Avatar
Car: 86 Z28/86 IROC
Engine: 305 LG4/ LT1
Transmission: 700R4/4L60E
Blowthrough holley
Looking to put a kit together consisting of a H1C/HX35 holset on my LG4 305, theres a guy looking to get rid of a 4150 holley which would be perfect to convert to blow through, but its 850cfm, to big for a 305? I never played with carbs before but figure id give it a shot and do something different. Thanks
Old Oct 7, 2013 | 03:03 PM
project89's Avatar
Re: Blowthrough holley
yes its to big
Old Oct 7, 2013 | 03:12 PM
cumminsN14's Avatar
Car: 86 Z28/86 IROC
Best to find a 600-650?
Old Oct 7, 2013 | 03:54 PM
project89's Avatar
correct u size the carb as u would for an na engine
look on fleabay or craigslist or even the classified here get a carb that needs a rebuild cheap since u will be tearing the whole thing down anyway to modify it
u should be able to find one in the 30-50$ range
Old Oct 7, 2013 | 04:01 PM
cumminsN14's Avatar
Car: 86 Z28/86 IROC
Thanks, i knew the 850 was to big for NA but didnt know if it be different with forced induction.
Old Oct 7, 2013 | 08:35 PM
NemeSS-TyranT's Avatar
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
theres alot of good basoc info on turbomustangs/turboforums concerning bt build,sizing,parts,tricks,etc. but seems like a 850 may be too big but you may still be able to mod it and use mixin and matching w other carb parts. base plate, main bodies,etc.
if your not alredy a member, should check it out. alot of good info there
Old Oct 9, 2013 | 10:06 PM
Drac0nic's Avatar
From my understanding of the blow throughs, start with a carb that's fairly conservatively sized for your engine. An 850 would not be it. You can end up with signal troubles if you get some huge carb to stick on a BT.
RaverRacerX
Mar 17, 2026 01:49 AM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
