Need some help????
Old Oct 28, 2013 | 04:29 PM
my hemi's Avatar
Car: A few things lol
Engine: 350 tpi supercharged and a 383 stro
Transmission: Both 700r4s
Axle/Gears: 3.23s and 3.54s
Need some help????
Hi I was wondering if anyone knows of how info on the old style paxtons for the TPI cars...I just had an SN92 installed on my wifes 91 z28 350 tpi with speed density..so far I did one step colder plugs,255 lph fuel pump, I set the timing at 6 degrees, fuel pressure is at 52 psi..im installing an AEM air fuel gauge this week just had the bung welded to see what air fuel is...my question is I tried making a tube to go to the stock air back I did I have to take pictures of it so you guys can see what I mean...well while it boost it was bogging really bad...so I let off then I thought to myself wonder if the tube isn't allowing a lot of air flow so I disconnected and wow the blower is whistling so loud now and no more bog...could it be the tube is crap its a black plastic tube or can the stock air box be restrictive??? any help would be great I don't see many of these cars with blowers lol..oh yeah I sent the blower to paradise wheels to be upgraded to the better bearing impeller it makes about 7-8 psi....nice blower...so far...lol thanks for any help...
Old Nov 2, 2013 | 07:11 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: Need some help????
I have the same setup my Paxton has a filter mounted in the inner fender well on the driver's side for air some pics would help
Old Nov 2, 2013 | 10:05 AM
my hemi's Avatar
I fixed that problem..i shortened the tube mounted the filter by the fender well...but im having another problem going lean in boost..do you use an FMU is so which one you have any pics of how its hooked up?...
Old Nov 2, 2013 | 03:25 PM
tom86iroc's Avatar
Car: 1986 iroc
for along time I could never go WOT cause it was lean I ended up putting an external mallory EFI pump with boost ref reg. with #8 lines to solve my problem I don't use an FMU since I went to the bigger pump and and Inj. 36 or 42 one thing i did have to do when I installed the mallory pump was to remove my factory reg it wouldn't flow enough thru it so it regulated the pressure instead of the aftermarket regulator and I use a factrory prom no burnt chips or anything and it runs just fine
Old Nov 2, 2013 | 04:19 PM
my hemi's Avatar
Thanks for the info I think im going to try an FMU see if that can get me by for now...I hope it does...
