Next step...
Car: 91 Formula
Engine: 5.0 tpi slow
Transmission: WC t-5
Next step...
I'm at a bit of a crossroads with my car. Current setup is a 358, 10.2:1 compression, fastburn heads, zz409 cam(I know, I know)and superram. Other mods as well, but those are the big ones. Also a dana 44 rear, shifting my own gears.
Traction is the biggest issue the car has on street tires.
I'm trying to figure out the next step now. I like the idea of a centrifugal, although I'm not opposed to a turbo, I hank the blower would be simpler. I have also considered spraying it up to a 200 shot. I know the compression is kinda high for forced induction, could I keep boost low on pump gas for the street, then race gas for the track on higher boost? Just lookin for some input.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Next step...
Originally Posted by 2slow5.0
I know the compression is kinda high for forced induction...
Could I keep boost low on pump gas for the street, then race gas for the track on higher boost?
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Next step...
E85 would be ideal for that motor
Else good intercooling can get away with some boost on pump gas. Meth inj to be safer. If you have a real good air to air or better yet, air to ice water intercooler system, it will work fine
Just watch the timing with any fastburn head chamber. It can be sensitive. Pull alot and sneak up on it in the tune
Nitrous however is the easiest to work with. Dont have to change anything
Car: 91 Formula
Re: Next step...
Thanks for the input. Maybe I'll start looking into the boost route. E85 , strangely,is still not that common here. Fabbing up for an intercooler doesn't bother me at all. The bottom end is strong enough to handle just about whatever I want to throw at it (Kryptonite crank, Oliver rods, Ross pistons, billet mains, 4 bolt bowtie block). I have another set of heads I could put on, but I think it would be a waste with the superram.
Anyone here running boost and nitrous????
