nitrous+vortec heads anyone???
Old Apr 5, 2017 | 05:27 PM
mike22115's Avatar
Car: 1990 firebird formula
Engine: 355 HSR comp xfi 268 vortec heads
Axle/Gears: 3.27 BW 9bolt
so I'm in the process of fine tuning my nitrous set up,im spraying a 150shot. did a pass pulled a plug and appears that the plug I'm currently running is to hot. its a heat range 5. so I was going go to a heat range 7. how ever for the vortec heads I cant seem to find any 7's seems like they go from 6 straight to 8.
just wondering what everyone else is running on their set ups as far as spark plugs
Old Apr 6, 2017 | 07:15 AM
86CamaroDan's Avatar
Car: 86' IROC
Engine: Supercharged 350
Axle/Gears: 3.45
Re: nitrous+vortec heads anyone???
AC delco's (what i ran for the longst time) run a R44LTS stock, and only offer a plug 2 steps colder (R42LTS) After 500 miles on my blower car they looked great, so i would probably give them a shot.
Old Apr 6, 2017 | 08:20 PM
mike22115's Avatar
thanks for the reply ill give them a try and see what happens and let you know
Old Apr 7, 2017 | 07:11 AM
Car: 86' IROC
Axle/Gears: 3.45
PS. I belive R42LTS6 burns just about as hot as the R44LTS. I would have to double check. I found the chart yesterday but cant seem to find it again. Regaurdless the R42LTS's are what i ran all last year without issues on 5.5lbs of boost
Old Apr 7, 2017 | 11:38 AM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
NGK BR7EF. 0.708" reach taper seat
Old Apr 7, 2017 | 02:51 PM
Car: 86' IROC
Axle/Gears: 3.45
isnt the 7 heat range for NGK's a good NA starting point? I was under the impression you would want a 8 or 9 for power adder cars?
Old Apr 11, 2017 | 05:37 PM
mike22115's Avatar
went and picked up a set of these and going to test them tonight or this weekend. I'll post back and let everyone know how it goes
Old Apr 13, 2017 | 11:40 AM
irocman7's Avatar
Car: 89' Sunset Metallic Orange Iroc-Z
Engine: Forged 383
Transmission: TR6060
Axle/Gears: 4.11 9 inch
I am running a NGK 1049 B8EFS. It's a heat range 8, so far no fouling out with regular driving. It should take me to a 200-250 shot.
I ran a rt44 with 100 shot, and it was a little hot, so I jumped to the 8. The 1049 is pretty common and easy to find. You probably don't need an 8 for a 150 shot. The 7 will be fine.
