Cubes and turbo... check this out!!!
Car: '89 Firebird
Engine: 7.0L
Here's an example of what cubic inches does with a turbo. The car was on only 12 psi.
http://vca1.viperclub.org/ubb/Forum2/HTML/000475.html
and here's the racing video.
http://www.mydigitalvideo.net/player...h=demos$others
The Supra that walks by in the end has 900+ RWHP.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Now that is what I'm talking about! More fireakin power than a rich man knows what to do with besides brag and floor it less than 4 seconds at a time.
Seriously, that is why the import idiots will never get power, its all in the cubes, then you boost it, don't even have to rev it that high. Imagine a high revving 540 big block with a pair of turbos, maybe 2000hp or so.
I've got a lumberyard in my shorts.
Re: Cubes and turbo... check this out!!!
ummmm.....no
it has 874rwhp. not 900+. Dont mislead people
Car: '89 Firebird
Engine: 7.0L
This whole race thing was detailed much better at the Corvette forum where the Supra owners posted. Without reading through it again I thought the one Supra made well over 900 with a 50 shot of nitrous.
Sorry, I did get it wrong. The Viper was boosted to 12 psi and made 931 RWHP SAE uncorrected. I got it all mixed up.
here some highlights from hennessey's post on this.
"Here are a few details for my fellow power freaks:
Venom 800 Twin Turbo, running 12 psi boost, motor has stock bottom end. Best pull of the day netted an actual power output of 931 rw hp and 952 rw lb-ft. This was done in an ambient air temp of 61 deg F. The numbers corrected down to SAE and were 883 rw hp and 902 rw lb-ft. 7 pulls were made today and peak SAE corrected numbers were between 840 - 883 rw hp (depending on heat soak, fuel calibration). This V10 is making over 700 rw hp from 3500 rpm to 6000 rpm!"
Although not too clear, it appears the viper ran bryce supra at 7 PSI of boost
BumpaD82
Feb 26, 2016 02:57 PM
Numbah-1
Sep 12, 2015 08:57 PM
