12 Rib Belts for Procharger?
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I just converted my car over to a 12 rib set up and added the ASSC support brackets to my car so the lowest idler pulley by the crank is now deleted from the set up. Running a string line around the crank and blower pulley shows that I need a 62 inch belt however I can't seem to find one anywhere in that size. Only 64 or 61 inch belts. Anybody else here that has done this conversion, what belt are you using? Thanks.
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: 12 Rib Belts for Procharger?
how much room is on the adjuster? cant squeeze a 61 on with the adjuster all the way in?i'm going cogs motor isnt in the car yet
Car: 85 Iroc-Z
Im not using the procharger tensioner. I've added a spring loaded tensioner.
For the OP you can get the 61 on. Back the adjuster all the way. Get it started as far as possible on the head unit pulley. Bar the engine over by hand to install the rest of the way. Heres the Gates page for a 62.08 belt just in case.
valencia1z
May 13, 2017 05:05 PM
