Mods to do before I get N2O
Old Feb 7, 2002 | 01:11 PM
Casey'91Z28's Avatar
I plan on getting a Nitrous Express kit for my car soon when I have plenty on time to do it right(College Student). So what would be some good mods to do to my car before the N2O. Another question I have is that I made a cold air intake from Home Depot stuff, will I be able to use this or will I have to put the stock intake back on. My mods are in my signature. Thanks.
Old Feb 7, 2002 | 01:19 PM
91-ZZ4-Z28's Avatar
I think you should be able to use your intake stuff just fine. I did a total fuel system upgrade bigger fuel pump, injectoers and a AFPR. Also when you get your kit look in to what they call a window switch this has an RPM window that the N2O can opperate in so it never hitts to low or too high.
Old Feb 7, 2002 | 01:54 PM
I'll look into the window switch, that sounds like a good feature. I think I will do the AFPR, but do I really need to upgrade the fuel pump and injectors on my 305?
Old Feb 7, 2002 | 05:53 PM
91-ZZ4-Z28's Avatar
I would get a gauge and see if you system is still up to OE specs if so then you are probably ok if not then get them.
PS- I responded to you post in the TPI board also and then saw it was the same person sorry.
starliner
Feb 9, 2016 08:18 PM
Quzyle
Oct 15, 2015 03:35 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
