Building my own nitrous system...
Old Mar 19, 2002 | 10:49 PM
LottaBallsCamaro's Avatar
I want to add a hidden 100 shot of nitrous and would like to build it myself. What is needed in a system and does anyone have any system diagrams? Also, My MAF sensor doesnt run hot enough that it will ignite nitrous right?
Old Mar 20, 2002 | 10:17 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
If you inject the nitrous fuel mix into the induction before the MAF you are asking for trouble. I doubt it will cause the mix to explode, but it will certainly cool the wire off tremendously therefore causing a lean/rich condition. You will be better off introducing it after the MAF and if possible after the TB.
Old Mar 20, 2002 | 01:01 PM
383GTABoy's Avatar
Car: 88 GTA + Dakota on N20
Engine: 383 4 bolt
Nitrous its self is not flamable but if it is a wet shot through the maf it does not sound like a very good idea to me. Lets see here's the parts i can think of off the top of my head. Bottle, pressure gauge, 4an line between the bottle and solenoids, solenoids (fuel and nitrous),Jets,Fogger or plate, Relay and some extra wire,wot switch, 4an line from both solenoids to plate and a 4an line from shrader valve to fuel solenoid. Oh yea dont forget to remove the inards of the shrader valve "or your gonna have a bad time" (southpark). Yes you need the pressure gauge i don't care what anybody says. If you have never done a nitrous kit before i would not recomend doing it this way. It would probably be alot easier and cheaper to just buy a kit from nos. My friend has a 91 bird and all you can see on his is the 1/4 inch thick plate between the tb and plenum. the rest of the lines he just covered in that black coily stuff that you can get from any auto store.If anyone else wants to add anything i might have forgotten feel free.
Old Mar 20, 2002 | 04:19 PM
83 Crossfire TA's Avatar
It has been done with a dry shot that way. There used to be (might still be) an N2O setup for LS1's that a bunch of guys called the 'Death Bag of Nitrous.'
Basically, a duffle bag with a single braided line going to a valve and a fogger that you mounted in front of the LS1's MAF. The cold blast would force the PCM to pretty much dump as much fuel as it could into the engine via the injectors.
I don't know if anyone ever blew a car up with one, but I would be skeptical with a setup like that on an L98, mostly because the ECM is slower and I'm not sure it would react fast enough or severely enough to give you enough fuel.
Old Mar 22, 2002 | 09:18 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I can see the mushroom cloud from here.
Old Mar 23, 2002 | 06:22 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
like this
Old Mar 24, 2002 | 01:36 AM
383GTABoy's Avatar
Engine: 383 4 bolt
b4ctom1 cant you ever!!! say some thing positive, or do you just come here to put everybody down. Some people are just learning just like u and i once did. U dont need to rip on them for no aparent reason.
Old Mar 24, 2002 | 01:59 AM
I missed something
Who are we ripping a new one and why?
I think that I said there used to be a setup like that, that apparently worked but I wouldn't trust on my car, and he said that basically he could see the thing blowing up.
I've seen good setups rip motors apart, and I've seen some really cool fireballs. But it's not like I've learned better and would never run N2O on something, I own a NX GenX kit with a 15# bottle...
Old Mar 24, 2002 | 02:03 AM
How about, here is what happens if you're lucky and you have a N2O explosion (I bought my current project car with an idle problem among other things):
(man that's really annoying how the javascript trunkates long url's when inserting pics)
Old Mar 24, 2002 | 02:13 AM
383GTABoy's Avatar
Engine: 383 4 bolt
Sorry but the last two post i have seen him in he just seemed to be making fun of people who didn't exactly seem to know that much about power adders. If he had some actual usefull info about why the motor would blow or explain why it was a bad idea instead of making fun of them I would understand. Sorry if i have offended anybody.
Old Mar 27, 2002 | 10:14 PM
I didnt think about it cooling the MAF. I am just going to buy a plate system probably.
Old Mar 28, 2002 | 12:33 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I guess I should have just told you not to try to nickel and dime your own nitrous system together, usually people beat me to the punch on this one but disregard this idea if you dont care about all the things that can go wrong while piecing together a nitrous system. It is not a matter of being negative. It is like seeng guys talk about building a turbo system because they cant afford the blower and want more power. there are, I will surmise a couple of people that might try to make tis claim but there is no way I will believe it (so dont even try responding you guys that think you have built one). now that I have said that let be try to help you in your endeavor. here is the most hidden system from NOS. but my favorite is the NOS "dry" system with the microswitch hidden between the TPS and the TB ( I'll try to get a pic of it) and the nozzle into the underside of the airbox and line up between the radiator and A/C condensor (through the radiator top cap) and the wires and lines covered in loom and the selenoids simply sprayed flat black. and the bottle mounted in the spare tire well. I hope this has helped to lower the offense I gave to you.
Old Mar 28, 2002 | 01:48 PM
Omega's Avatar
Engine: LS1 / LS3
You don't need to add a mechanical switch to the system. There is a company (don't know the name of it) that splices into your TPS connector. When this gizmo reads the correct voltage (user determined) it will activate a relay. It is completely stealth since you can hid the box and where you spliced into.
Just a thought.
I am with B4Ctom1, buy the kit, you will thank yourself later.
ZEEYAA
Apr 16, 2023 08:29 PM
racereese
Oct 3, 2015 03:46 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Zell1luk
Sep 29, 2015 10:36 AM
Jlanz55
Sep 29, 2015 08:55 AM
