Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Calculations Error
Old Nov 22, 2006 | 04:41 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
Calculations Error
I am referring to this:
https://www.thirdgen.org/calculations
I was trying to calculate my speed, basically to double check my speedo. It says Tire Radius, RPM, Rear End Gear, and Transmission Gear. So I enter:
Tire Radius: 8.75
RPM: 2300
Rear End Gear: 3.42
Transmission Gear: 1 (4th is direct in the T5, right?)
and get like 36 MPH. Basically, I was going 70, so something wasn't right. Just out of curiosity, I enter in my Tire Diameter, and get 70, so I think that Radius should read Diameter. Please correct me if I'm wrong.
Old Nov 22, 2006 | 05:11 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
did you measure wheel+tire radius or just the wheel? because my wheel radius (center of the wheel to the ground) is about 13"
Old Nov 22, 2006 | 05:39 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
I guess I figured that with rim and tire (15" rims) it was 17.5, but that might be a bit to little, now that I look at it. Ill recalculate when I break out the tape measure.
antman89iroc
36
Jan 31, 2016 08:42 AM
3rdgenparts
Sep 28, 2015 10:47 PM
mfp189
Sep 27, 2015 09:25 AM
BWilcox
Sep 20, 2015 12:19 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
