Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Vb Garage question?
Old Jan 17, 2007 | 04:00 PM
Ian'sTA's Avatar
Car: 1982 Trans Am
Engine: Chevy 350
Transmission: Turbo 350
Axle/Gears: Stock 2.93
Vb Garage question?
The pic limit of 150kb...what does that translate into pixel size? What's the largest pixel size I can do? Also, where do other members access your vb garage from? Thanx!
Old Jan 17, 2007 | 04:12 PM
JT's Avatar
JT
Community Administrator
File size limit and pixel size is not exactly one and the same. There is no set pixel size limit, as long as the picture itself does not go over the file size limit. Members have posted fairly large (pixel) size pictures, and some quite small ones as well.
The vB Garage is accessed through the menu bar that is on each vB webpage: https://www.thirdgen.org/forums/vbgarage/
You can quickly access an individual's vBGarage if you're viewing one of their posts, as you can click on the icon:
that appears in their "postbit".
Old Jan 17, 2007 | 04:16 PM
Ian'sTA's Avatar
Car: 1982 Trans Am
Engine: Chevy 350
Thanks JT! I'll play around with it & see what size I like best. Please also read my post to you about classified posting. Thanks again!
Old Jan 17, 2007 | 04:26 PM
JT's Avatar
JT
If you have the original size, you can use the crop and resize tools to trim the image down. If you resize, you might want to ensure the program is set to keep the aspect ratio the same, otherwise, your image will look distorted (ratio wise). A free graphics manipulation tool is called The Gimp, and it can run on Windows.
Vintageracer
Jan 10, 2020 05:33 PM
92GTA
Apr 9, 2016 07:39 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
PestilenceIV
Aug 20, 2015 02:33 AM
redmaroz
Aug 16, 2015 11:40 PM
