Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
why?
Old Apr 27, 2008 | 08:54 PM
88bird?'s Avatar
Car: 1988 Pontiac firebird
Engine: built 350
Transmission: 700r4 built up to 600hp
Axle/Gears: stock for now
why?
wont my sig show up? I made one and hit save and i cant see it....?
of course it works now...you can delete this thread...
Old Apr 27, 2008 | 09:23 PM
JT's Avatar
JT
Community Administrator
Re: why?
By default, if you have Show Signature set to Yes in your userCP, when you create a new thread, the "Show you Signature" will automatically be checked, which is an option below where you type your message. Your signature will then show - as it did here.
However, if you reply to a thread, and if you want your signature to display, you will have to manually place check in the box for "Show your Signature" each time, which is the option below the where you type your message.
This is how the old vB 2.x that we used was tweaked, as it helps reduce redundant use of one's signatures, especially for those who may post in the same thread multiple times.
It's been this way for several years.
