Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Trouble logging on
Old May 1, 2008 | 10:21 PM
gatorcola's Avatar
Car: 88 IROC Z Vert CZA3
Engine: LB9 5.0 tpi
Transmission: MM5 5 spd
Axle/Gears: G92 Performance
Trouble logging on
Just a heads up for you. Significant delays when logging on and the board is very slow: guess you guys know it too but just in case . . . .
On the home page there is all this:
warning: fsockopen() [function.fsockopen]: php_network_getaddresses: getaddrinfo failed: Name or service not known in /var/www/html/includes/common.inc(1185) : eval()'d code on line 5.
warning: fsockopen() [function.fsockopen]: unable to connect to www.linkworth.com:80 (Unknown error) in /var/www/html/includes/common.inc(1185) : eval()'d code on line 5.
warning: fsockopen() [function.fsockopen]: php_network_getaddresses: getaddrinfo failed: Name or service not known in /var/www/html/includes/common.inc(1185) : eval()'d code on line 13.
warning: fsockopen() [function.fsockopen]: unable to connect to www.linkworth.com:80 (Unknown error) in /var/www/html/includes/common.inc(1185) : eval()'d code on line 13.
warning: fsockopen() [function.fsockopen]: php_network_getaddresses: getaddrinfo failed: Name or service not known in /var/www/html/includes/common.inc(1185) : eval()'d code on line 21.
warning: fsockopen() [function.fsockopen]: unable to connect to www.linkworth.com:80 (Unknown error) in /var/www/html/includes/common.inc(1185) : eval()'d code on line 21.
Old May 1, 2008 | 10:58 PM
jwdomino's Avatar
Car: 82 Trans Am
Engine: 13:1 383 stroker on e85
Transmission: t-56
Axle/Gears: ford 9" locker 3.70
Re: Trouble logging on
ditto have to log on thru a link saved about a brake topic i'm following vs. the main thirdgen.org address
Old May 2, 2008 | 01:20 AM
JT's Avatar
JT
Community Administrator
Thanks. I see there's an issue. We'll work on it.
Thanks.
Old May 2, 2008 | 02:02 PM
JT's Avatar
JT
I fixed the issue with the errors on the frontpage and the delays. Should not be an issue again.
Thanks.
mrbird
Oct 20, 2015 03:43 AM
L98GTA87
Oct 19, 2015 10:43 PM
Lmancha96
Sep 25, 2015 08:11 PM
BWilcox
Sep 20, 2015 12:19 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
