Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
I know this is petty but
Old Aug 3, 2008 | 10:38 AM
C.M.Jones's Avatar
Car: 84 Camaro, 90Firebird, 87Transmaro
Engine: custom 5.7, 5.0 , 6.5 Turbo diesel
Transmission: 4spd, auto, auto
Axle/Gears: 2.77 posi
I read that 100 posts make you a senior member has that changed?
if so what has it changed to?
if not why aren't I and MANY others not senior members yet?
Old Aug 3, 2008 | 11:15 AM
JT's Avatar
JT
Community Administrator
Re: I know this is petty but
If I recall, it was adjusted once, and then it was adjusted back. That has been quite some time ago.
Currently, it takes 250 posts (in forums that count) for Senior Member.
As you may know, there is currently no difference whatsoever (permission/access wise) between Junior Member, Member and Senior member.
Old Aug 4, 2008 | 06:06 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
yeah man,makes no diff. at all,only gets diff. if you have amin/webmaster or moderater under your user name.
Your 2 posts away from being a senior member.(congrats)
Old Aug 27, 2008 | 03:39 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
weird it seems like i was somewhere around 3-400 before i got senior status
Old Aug 27, 2008 | 04:43 PM
JT's Avatar
JT
Back around 2006/2007 it was 500 posts. Since that's when you also joined it makes sense to me.
It was re-adjusted after someone had adjusted it on their own (if I recall).
Anyway, the bottom line is that 250 = Senior Member status (today) and it doesn't differ from Junior Member status besides the text itself.
murd450
Jan 25, 2013 04:46 PM
Aquafied Iris
Dec 29, 2011 04:59 AM
Zap Racing
May 21, 2005 08:08 AM
injdinjn
Southern California Area
Mar 23, 2005 04:29 PM
JERRYWHO
Jan 30, 2003 10:58 PM
