Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Signature Question
Old Dec 5, 2008 | 12:40 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Signature Question
Is there any way to set my sig so that it comes up after every post I make? It seems as if it only shows when I start the thread, and not just comment on it.
Thanks.
Old Dec 5, 2008 | 02:08 PM
JT's Avatar
JT
Community Administrator
Re: Signature Question
In short, no.
When you reply to an existing thread, you must place a check mark in the box for "Show your signature" which is under the Miscellaneous options - which is under the area you type your message in.
When you post a new thread, the check mark in the "Show your signature" will default to ON - as long as you have a signature.
It was setup this way, years ago, to help minimize redundant signatures being posted by the same member in the same thread.
Old Dec 5, 2008 | 02:32 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Ok thanks for the info.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
