Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Trouble uploading pics
Old Apr 13, 2011 | 10:58 PM
86rocjoc's Avatar
Car: 1986 Iroc Z-28
Engine: LB9
I'm having trouble u/l pics. Is there something special I need to do?
Old Apr 13, 2011 | 11:18 PM
JT's Avatar
JT
Community Administrator
Re: Trouble uploading pics
Please see the following thread for brief instructions on how to post images:
https://www.thirdgen.org/forums/prob...mages-tgo.html
If this does not help, please describe the issue. The most common issue is an Upload Failed error, which should also come with a notice that the file being uploaded exceeds the allowed file size. This is usually the issue.
In that case, you will need to use photo editing program to scale and/or crop the photo down to acceptable size.
There are two programs that I personally recommend when needing to edit images. Both programs are free:
The Gimp: http://www.gimp.org/
This program can be quite complex, thus, it can take time to learn how to use. However, it's a powerful program when needing to edit photos.
IrfanView: http://www.irfanview.com/
This program is lightweight and pretty easy to use, although it's not as powerful as The Gimp. This program will do your basic editing (setting dimensions, cropping, etc.).
Using IrfanView as an example, which after you download and install it, click on File and Open to locate the image on your computer that you wish to edit. To simply scale the photo down to fit a set pixel dimension, you can click on Image and Resize/Resample. Under the Set New Size, enter the dimension you want the image to be. Make sure Preserve Aspect Ratio is enabled so that the image isn't distorted. With the Preserve Aspect Ratio set, you will only be able to enter a Width or a Height and the system will calculate and fill in the other value to preserve the aspect ratio.
If you still need help, you can email me at jt@thirdgen.org and I'll further assist.
Good luck!
Old Apr 13, 2011 | 11:35 PM
86rocjoc's Avatar
Car: 1986 Iroc Z-28
Engine: LB9
Thank u for th reply JT. I apologize for posting it in the wrong spot. What are the dimensions for pics on here?
Old Apr 13, 2011 | 11:53 PM
JT's Avatar
JT
It depends on where they're going. Attachments to posts are approximately 1mb per file. The Garage feature allows up to 6 files with each being up to 150KB. The photo album is more restrictive.
Old Apr 14, 2011 | 12:03 AM
86rocjoc's Avatar
Car: 1986 Iroc Z-28
Engine: LB9
Ok..i think i figured it out. I posted 3 pics of my car and they showed up on the thread. TY again so much.
Hotrodboba400
Dec 10, 2019 07:07 PM
Lanz06
Mar 13, 2019 06:07 PM
gt4373
Sep 9, 2015 10:29 AM
rsrookie
Sep 5, 2015 07:08 PM
Jackrabbit501
Sep 2, 2015 09:14 PM
