Can't leave feedback for member ??
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I'm having trouble adding classified feedback for a member. This is the classified link:
https://www.thirdgen.org/forums/engi...eries-9-a.html
System tells me that the "URL is invalid " ??
Re: Can't leave feedback for member ??
John, when you use the thread URL, omit the trailing S in HTTPS that appears near the beginning of the URL.
ThirdGen now uses secure HTTPS. However, I recently found out the feedback program is not 100% compatible with this. When we use the as-is URLS, which have the HTTPS, the program rejects them. If submitted without the S (HTTP) it should go through.
Thanks for bringing this to my attention, as I have now been able to leave feedback for several members.
I need to ask: When will this be fixed? I have a lot of buyers that want to leave feedback; and it is tedious explaining to each one that they have to delete the "S".
Thanks, Kyle.
The issue was fixed several weeks ago. You no longer need to do what I outlined above in regard to changing the HTTPS to HTTP. Just copy/paste the link as normal and it should work.
