Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
time zone issues
Old Sep 6, 2017 | 07:26 PM
scarbucket's Avatar
Car: 1987 Firebird Formula
Engine: 355
Transmission: Borg Warner 5 spd
Axle/Gears: 3:43
time zone issues
shows the incorrect time for me all the time on posts i should be on usa central time not sure if its me or what lol
Old Sep 7, 2017 | 09:09 PM
JT's Avatar
JT
Community Administrator
Re: time zone issues
Yes, it's you. Specifically your computer or settings.
1) You need to make sure your computer time is correct.
2) You need to make sure DST is correct on your computer.
3) You need to make sure your UserCP has the correct time zone:
https://www.thirdgen.org/forums/usercp.php
4) You need to enable or disable DST check in UserCP:
5) You can't be running 3rd party extensions that block, filter and/or alter the site without accepting things may not work. Time Zone check and correction is performed through your browser using Javascript and relies on all the above to be correct.
