Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
2000 grand prix
Old Nov 7, 2019 | 12:17 PM
David Brinkman's Avatar
Want a title? Post!
Car: 2000 grand prix
Engine: 3.1
Axle/Gears: Hwy gears
2000 grand prix
I have a 2000 grand prix with the passkey 3 has a chip inside the plastic part of the key I just installed the new lock cylinder and i programed it and the security light is off now. But before I put the new ignition cylinder in and programed the keys I found that someone installed a aftermarket alarm system with the starter disable. I decided to take it out. I put the bigger starter wire back together that someone had to cut In two back together and now it turns over. But i found a big black and white striped wire and a smaller wire running out of the harness and was grounded to the body. I removed the wires from the ground. I checked them later or voltage cause I had forgot that they were grounded. The big black/white striped wire has a 5 volt current. And it was grounded? But the problem is even though the alarm is not blinking anymore cause I put in and programed a new cylinder lock and key the fuel injectors wont get a puls and it ran before I removed the alarm. I been stranded with no ride for over a week. Please someone help?
Old Nov 7, 2019 | 08:03 PM
JT's Avatar
JT
Community Administrator
Re: 2000 grand prix
This site (ThirdGen.org) is dedicated only to the Third Generation (1982-1992) F-Body (Camaro and Firebird).
You will have better help by finding and posting on a website that covers your vehicle.
You can try one of our sister websites:
https://www.internetbrandsauto.com/sites
padak
Jul 1, 2014 02:18 PM
90-irocdx3
Nov 19, 2004 02:51 PM
