T5 v6 to v8 swap??
I assume this is a swap to a V8....
Besides the V8 BH, you'll need a V8 T-5, flywheel, and clutch.
It will bolt right up; but the clutch gear splines won't engage a V8 clutch.
There's some clutch disc that people talk about that you can use to rig a 6-cyl transmission behind a V8. It's small, like an inch or more smaller than the right clutch, so it's weak.
THe 6-cyl transmission has the crappy wide-ratio 6-cyl gears; so you end up with the typical 6-cyl situation where EVERY shift is like the 1-2 shift int he 700 automatic. The motor goes from "scream" to "lug", with nothing in between. In other words, the ratios are too wide for a "performance" application; they're set up for a gas mileage application.
The 6-cyl transmission is also weaker than the V8 one, because the gear tooth part of the clutch gear is smaller in diameter.
The T-5 is already entirely weak enough: even the strongest V8 version is amazingly easy to tear up with a stock 305. While it's possible to make one live indefinitely by babying it sufficiently, I doubt that most of us here would go to all the trouble of a V8 swap, with the express intent of babying the car forever afterwards. We would probably like to equip the car in such a way that we could actually make use of the newly installed power.
Bottom line, just because it's "possible", doesn't make it "a good idea".
You need a V8 transmission, flywheel, and clutch, if you're expecting V8-like results.
Or, if you have a T-56, that's an even better way to go.
Car: 1992 RS
Engine: Vortec Headed 383 9.6:1
Transmission: TKO600
Axle/Gears: 10 Bolt Posi 3.73
Go with the t56 you have, it is a much better transmission. I got 30miles out of my T5 behind the fresh 383. Was a waste of time and money. Should have just upgraded with the motor instead of trying to cut corners to save myself money on the short term.
Hello, Michael
Aug 20, 2015 03:19 PM
