carb swap
Old Feb 19, 2010 | 12:45 AM
Ilike2stroke383's Avatar
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
carb swap
My gta has a 383 and a t56 and had an hsr setup. The last owner couldnt tune it so he just swapped a carb (a shitty edelbrock 750). I hate carbs and dont know a damn thing about them. Im not going to say i know everything about efi, but i def know alot more about it than carbs.
What all do i need to go back to efi? Also what are some good aftermarket efi setups? I know it isnt going to be cheap, but at least ill know how much to round up. If aftermarket, i would def like to able to connect my laptop and do some mild tuning as i go.
Thanks alot guys, sorry if this is stupid.
Old Feb 19, 2010 | 09:26 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: carb swap
Edelbrock makes the Performer and Performer RPM Pro-Flo multiport EFI systems to include pump, rails, sensors, manifold, TB, ECM, and harness, plus software for tuning.
You can send your crappy carburetor to me.
Old Feb 19, 2010 | 10:52 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: carb swap
Personally if it was me ide stealth ram it and use factory TPI electronics to run it.
Old Feb 20, 2010 | 09:23 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: carb swap
So would I, but if he's unwilling to learn how to tune a Carter style AFB carburetor, then would he really be willing to do what it takes to tune a 730 ECM? That was my reasoning for the complete aftermarket system.
Old Feb 20, 2010 | 11:48 AM
Engine: 383 Stroker
Transmission: t-56
Re: carb swap
Never said i was unwilling to tune. There just isnt any point. Its an edelbrock. Thats like trying to make a honda fast. Yeh dig?
Old Feb 20, 2010 | 02:48 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: carb swap
No.
It's pretty much the easiest four barrel carburetor to tune, and will support well over 500 HP.
But, if you think it's trash, I will take it.
Old Feb 20, 2010 | 11:20 PM
Engine: 383 Stroker
Transmission: t-56
Re: carb swap
You must know even less about carbs than i do. This is a vac secondary carb, i have a manual. Deff not worth it.
Old Feb 21, 2010 | 04:20 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: carb swap
depending what the original owner butchered up to do the carb swap , prob easier to get a used engine harness from a similar TPI car as well as the '165 computer if it has been removed.
Will need OE style computer controlled (small cap ) dist.
2nd hand perf intakes always on offer over in parts dept
https://www.thirdgen.org/forums/engi...ts/index3.html
Exp
https://www.thirdgen.org/forums/engi...y-stealth.html
https://www.thirdgen.org/forums/engi...rb-intake.html
https://www.thirdgen.org/forums/engi...tpis-58mm.html
Old Feb 21, 2010 | 06:53 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: carb swap
Carter style AFBs are not vacuum secondary, though they do have an air-valve over the secondaries that takes all of 2 minutes to remove.
Shall I pm you my address for you to send me your garbage?
Old Feb 21, 2010 | 12:10 PM
Engine: 383 Stroker
Transmission: t-56
Re: carb swap
yeah after you send me 200 bucks
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
cstrobel65
Aug 15, 2015 10:19 AM
