wire/ relay/ fuse identification
Old Jul 18, 2016 | 06:54 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Hey guys, I just fixed my rotting floor pans. I found out that they rotted because the P.O fed his subwoofer wire from the battery through a hole in the firewall that normally had a plug in it. I saw the water trickle down directly to the spot that I just put fresh metal in. While I was under there I saw some questionable wiring that I'm wondering if it is even original or was it all part of his sound system.
are the white connector, red and blue fuses, and little red connector original to the car?
are these relays original to the car? im assuming they're not since they're labelled APEX which is a sound system company but I'd like to make sure before I get rid of them
Old Jul 18, 2016 | 07:21 PM
TylerSteez's Avatar
Engine: 383 stroker
Re: wire/ relay/ fuse identification
also what is this relay behind the drivers side kick panel?
the blue wires run to those apex relays I posted a picture of
Old Jul 18, 2016 | 07:35 PM
TylerSteez's Avatar
Engine: 383 stroker
just reposted this in car audio since this doesn't really fit the electronics section. sorry mods
Hawkeye1980
May 29, 2016 09:02 AM
gt4373
May 10, 2016 11:08 PM
gt4373
May 10, 2016 11:07 PM
gt4373
May 6, 2016 11:13 PM
gt4373
May 4, 2016 11:04 PM
