Post your firebird pics
Old Aug 16, 2016 | 10:30 AM
  #1901
Re: Post your firebird pics
Originally Posted by maks10
^both beautiful cars!!! and I thought my 3 month run without a wash was pushing the limits lol ...especially with locusts everywhere earlier this year...what brake setup are you running?
Thanks, The brakes were new in 2000ish, BAER 13" and 2 piece rotors on all 4 corners.
Old Aug 16, 2016 | 06:42 PM
  #1902
r0t0rdr1ver's Avatar
Car: 1987 IZ, 1990 IZ, 1992 GTA
Originally Posted by CharcoalBird
Wow, great looking car! Love the color, what is it?
Old Aug 16, 2016 | 09:43 PM
  #1903
maks10's Avatar
Car: 1990 Trans Am
Axle/Gears: 3.08 posi
Ford shadow grey metallic
Old Aug 16, 2016 | 11:38 PM
  #1904
Thanks! Looks awesome, definitely suits the car.
Old Aug 19, 2016 | 03:45 PM
  #1905
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
Thank you! It's a ford color called dark shadow grey/gray metallic.
Old Aug 20, 2016 | 09:53 AM
  #1906
84Grn's Avatar
Car: 84 Pontiac Firebird
Engine: 368 6.0 LS
Transmission: 350 turbo+tci 3000 stall
Axle/Gears: 10 bolt 7.5 with 3.73 auburn posi-t
Before and after bought February 16 and after is current
Old Aug 20, 2016 | 09:57 AM
  #1907
84Grn's Avatar
Engine: 368 6.0 LS
Before
Old Aug 20, 2016 | 07:52 PM
  #1908
cam406406's Avatar
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
Originally Posted by sheikss
You got better pic of the hood and what brand it is?
Hood is a vfn
At show now. Come get some every body
Old Aug 20, 2016 | 09:38 PM
  #1909
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Took this out for tuning today. boost pulls on the street and enjoying the weather.
Old Aug 20, 2016 | 10:36 PM
  #1910
cam406406's Avatar
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
Looks good
How much boost?
Old Aug 20, 2016 | 11:27 PM
  #1911
Car: 87 TA clone
Originally Posted by cam406406
Looks good
How much boost?
Just looked over my logs. Hit 11.5psi at 5,500.
Old Aug 20, 2016 | 11:40 PM
  #1912
cam406406's Avatar
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
What kind of power does it make?
Time to turn it up
Old Aug 21, 2016 | 12:10 AM
  #1913
Car: 87 TA clone
Time to turn it up
should be making about 550hp on a stock 150k 5.3 LS. I don't know the formula to calculate HP off of injector duty % But at 9psi and my 55ish injector duty cycle someone on this forum calculated about 525hp. So add 2.5psi and a 68% injector duty cycle and figure what that's about. This are 72lb injectors btw.
The Supercharger is pulley'd down already so I cant increase boost anymore. But I'm already gathering parts for ported heads, lifters, cam etc. Should net me a minimum of 100hp easily on the cam alone without boost.
But I'm done at 650hp... no need for it on the street. its already almost too much unless I get a nice straight away and lots of room lol. But Ive done that and wanted more streetability so a tame motor and boost works for me.
Old Aug 21, 2016 | 08:12 AM
  #1914
maks10's Avatar
Car: 1990 Trans Am
somehow I don't beleive this due to the majority of our nature lol...car looks stunning !!!
As with yours cam!!! And what size tires you running in back? Love the look!!!
Old Aug 21, 2016 | 11:41 AM
  #1915
Car: 87 TA clone
haha u better believe it but thank you. Anymore and I'd be tempted to use it and prob total the car. Only reason its getting a cam is that I'm pulling the whole top end off to freshen the valve train and get new reman heads so the top end is like new. Since the motor has 150k of prob harsh miles I might as well throw in a cam to take advantage of the blower. I picked up a used Lq9 cam (stock 6.0 peanut cam) which would net me 40hp at 6000/6500 over the LM7 cam (stock 5.3 peanut cam). But Cammotion wants me to get a $400 custom cam lol which would net me like 100hp over stock and retain stock ish idling/driving at low RPM.
Old Aug 21, 2016 | 12:28 PM
  #1916
maks10's Avatar
Car: 1990 Trans Am
^ sounds cool....point exact lol but I'd beat up the setup you have now until a problem arises to have to refreshen the top end...I try not to be wasteful lol... either way great work!!!
Old Aug 22, 2016 | 06:42 PM
  #1917
russ&dars t/a's Avatar
Car: 92 Firebird Formula
Engine: 5.0 tbi
Transmission: 700r4/shift-kit
Axle/Gears: 4.11/posi
before
after
Finally got mine back from paint and body
Old Aug 22, 2016 | 07:49 PM
  #1918
Car: 1991 Firebird
Engine: 3.1L V6
Old Aug 22, 2016 | 09:07 PM
  #1919
maks10's Avatar
Car: 1990 Trans Am
@russ looking good, paint and body turned out great!
Cb , love that pic of your stance!
Old Aug 24, 2016 | 06:38 PM
  #1920
Engine: 5.0 tbi
Thank's Maks I'm pleased the way it turned out. Now I can start cleaning it and making it look the way Dar would like!
Old Aug 24, 2016 | 08:48 PM
  #1921
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Old Aug 24, 2016 | 08:59 PM
  #1922
Originally Posted by punkmaster98
"sir, I'm going to have to ask you to park farther away from the fire hydrant".
Old Aug 24, 2016 | 09:43 PM
  #1923
Car: 1984 T/A
Engine: LQ4
Old Aug 25, 2016 | 08:41 AM
  #1924
maks10's Avatar
Car: 1990 Trans Am
^punkmaster love the wheels, matches well without ground efx.
Old Aug 25, 2016 | 09:02 AM
  #1925
dmccain's Avatar
Punkmaster that car looks really good! Very clean I love the wheels also.
Old Aug 25, 2016 | 09:12 AM
  #1926
Car: 1984 T/A
Engine: LQ4
Thank you!
Old Aug 25, 2016 | 09:19 AM
  #1927
Rioux's Avatar
Trans Am 1985 350 300Hp, T5, 66157 Km, original paint.
Old Aug 25, 2016 | 02:50 PM
  #1928
maks10's Avatar
Car: 1990 Trans Am
^ beauty!!!! Engine specs?
Old Aug 25, 2016 | 03:17 PM
  #1929
Rioux's Avatar
Thanks !!
This is just a GM create engine 350 300HP #12355345 with headers Edelbrock and Magnaflow exhaust 3"
Old Aug 25, 2016 | 03:20 PM
  #1930
Car: 1984 T/A
Engine: LQ4
Originally Posted by Rioux
Thanks !!
Engine bay is mint!
Old Aug 25, 2016 | 07:46 PM
  #1931
Engine: 5.0 tbi
Here's a couple more updated picts. Thinking about putting Cragar SS wheels on it?
Old Aug 25, 2016 | 07:56 PM
  #1932
maks10's Avatar
Car: 1990 Trans Am
Russ, looks good I'd try to use the wheels you have now maybe polish them or black
Old Aug 25, 2016 | 08:10 PM
  #1933
Engine: 5.0 tbi
Yeah the cragars are probably kinda dated. Sorry had a 70's flash back LOL.
Old Sep 1, 2016 | 05:47 PM
  #1934
Engine: 5.0 tbi
Picked up some old school Centerlines for my 92. Can't wait till I polish them and install them . Only $200.00 for all four.
Old Sep 1, 2016 | 10:55 PM
  #1935
Car: 1984 T/A
Engine: LQ4
Annual BBQ with some friends. I was the only bird to show up. The few and the proud
Old Sep 2, 2016 | 06:19 AM
  #1936
maks10's Avatar
Car: 1990 Trans Am
^nice!!!! A very lonely bird lol but all look stunning!
And Russ great pick up! Can't wait to to see them on
Old Sep 5, 2016 | 07:34 PM
  #1937
Engine: 5.0 tbi
Got the Center lines on today and had to change the electric fan. Here are some pict's of engine bay before I start on it.
Old Sep 7, 2016 | 04:25 AM
  #1938
maks10's Avatar
Car: 1990 Trans Am
Russ looks better with new wheels! Gotta shine up the tires to match those pretty wheels!
Old Sep 12, 2016 | 06:14 AM
  #1939
Engine: 5.0 tbi
Started on engine this weekend . Still needs more cleaning. Pict's not very good [phone doesn't take very good pict's in my garage]. Will post better ones later [taking my camera with me]
Old Sep 12, 2016 | 09:31 AM
  #1940
RamAirZ's Avatar
Car: 1999 Camaro Z28
Engine: 5.7
Old Sep 12, 2016 | 10:49 AM
  #1941
maks10's Avatar
Car: 1990 Trans Am
^sweet!!!! Love the hood Specs?
Old Sep 12, 2016 | 02:50 PM
  #1942
RamAirZ's Avatar
Engine: 5.7
Thank ya! It's an 88' GTA, 5.7. 18x10 xxr's with 285/40 Goodyear Supercars on all four corners, wing from my 2000 TA, RA2 hood, traded my original GTA wheels for the black paint work and spoiler mounting. Slightly modded drivetrain, bout to dive into it some more. Redone tan leather and swapped a 4th gen A4 console in
Old Sep 13, 2016 | 08:50 AM
  #1943
Car: 1991 Firebird
Engine: 3.1L V6
What was the offset on the front and how big of a spacer did you have to use?
Old Sep 13, 2016 | 06:42 PM
  #1944
RamAirZ's Avatar
Engine: 5.7
It's +20 on all 4 and 1" spacers plus the front I used the factory spacers to clear the hub dust cap. Once I swap my new brakes on I should be able to ditch that.
Old Sep 13, 2016 | 08:59 PM
  #1945
MASON1259's Avatar
89 Formula 5 speed.
Old Sep 14, 2016 | 06:20 AM
  #1946
maks10's Avatar
Car: 1990 Trans Am
^Great choice on wheels! What tire sizes you running?
Old Sep 15, 2016 | 07:40 PM
  #1947
MASON1259's Avatar
Thanks.
18x9 with 255/40-18
18x10 with 285/35-18
Old Sep 15, 2016 | 09:05 PM
  #1948
Engine: 5.0 tbi
Here are some better engine pict's.Still a little more work to do .Got a new headliner plastic going to paint it to match rest of interior. Then work on the exhaust
Old Sep 15, 2016 | 09:15 PM
  #1949
Drove her to work today and had to get this shot, wish I could get a better shot but that's about the best I could do.
Old Sep 16, 2016 | 06:16 AM
  #1950
dmccain's Avatar
Sweet
