87 camaro z28 convertible build
Old Nov 18, 2016 | 08:45 AM
ctoledo0834's Avatar
Engine: 350 carb
Transmission: th-700r4
Hi everyone so this is my 87 camaro that has been in my family for almost 20 years. I recently bought it from my brother a few months ago and have done a lot of work to it. Here are some pictures of what has been done.
Old Nov 18, 2016 | 09:03 AM
Engine: 350 carb
Re: 87 camaro z28 convertible build
Before paint and cables were cleaned up
Fourth gen washer bottle swap
Also did the fourth gen under the battery bottle
Old Nov 18, 2016 | 10:11 AM
Engine: 350 carb
Was able to finish the rear end swap yesterday
New 94 posi disc brakes with 3.42 gears
In with the new
Decided to Por 15 the rear and other parts while I was at it
Out with the old
Old Nov 18, 2016 | 10:18 AM
Engine: 350 carb
Also was able to Por 15 the rear of the car while the rear end was out
Old Nov 18, 2016 | 10:19 AM
Engine: 350 carb
Looking to change the top this weekend if I get a chance. Here are some pics of the frame before I cleaned it up and paint it
Old Nov 18, 2016 | 10:28 AM
Engine: 350 carb
Floor are next after the top is changed
Old Nov 18, 2016 | 10:32 AM
Engine: 350 carb
All new front suspension with energy suspension bushings and new center drag links etc
Old Nov 18, 2016 | 10:49 AM
rarebmx's Avatar
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
Floorboards look like factory yellow. Was original color yellow?
Old Nov 18, 2016 | 11:15 AM
Engine: 350 carb
Yea I believe it was
Old Nov 18, 2016 | 11:17 AM
rarebmx's Avatar
That would be the only 87 Yellow convertible to be known...
Old Nov 18, 2016 | 11:26 AM
rarebmx's Avatar
Is the original console in the car with the RPO codes?
Also does this car have the "special edition badge or the 29th Anniversary map pocket on the dash?
Old Nov 18, 2016 | 11:36 AM
Engine: 350 carb
I would have to check the console when I get home. No it doesn't have the badge/pocket. The engine bay had parts that were yellow and there's parts were the blue paint is chipping and it's yellow underneath
Old Nov 18, 2016 | 11:40 AM
rarebmx's Avatar
I'd research the car more. According to ASC no yellow Z28 or IROC convertible ever rolled off their line in 87.
Must have the RPO sticker with your cars VIN on it to prove it.
I assume this is a 6th digit of the VIN #2 car.
Old Nov 18, 2016 | 12:50 PM
Engine: 350 carb
Yea the 6th number is 2. I can send you the vin if you want
Old Nov 18, 2016 | 01:16 PM
Engine: 350 carb
How would I know if it's a z28. Does it say it in the vin
Old Nov 18, 2016 | 04:58 PM
Engine: 350 carb
Rusted out cover
Old Nov 18, 2016 | 05:05 PM
Engine: 350 carb
My 87 and my brothers 89
White leds
Old Nov 18, 2016 | 06:19 PM
rarebmx's Avatar
VIN won't tell you much but 8th digit being an 8 or F would say Z28 or IROC.
You need to find the label inside the console with all the codes.
Old Nov 18, 2016 | 08:39 PM
Engine: 350 carb
Ok. I checked when I got home but it's not there. I think I might have saw it on my old console lip. I'll check tomorrow
Old Nov 18, 2016 | 08:42 PM
Engine: 350 carb
The 8th digit is an h
Old Nov 18, 2016 | 09:19 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
H= LG4, i believe, base line eng.Iroc wouldve been L69 at least, Z28 possibly LG4 std.Someone correct me if im wrong though.
Regardless it sure looks like a factory yellow car, which is pretty rare for 3rd camaros.That alone makes it desirable.More so if its a factory conv/yllw car, but i would change it back to yellow.Keep up the good work.
Old Nov 18, 2016 | 09:26 PM
Engine: 350 carb
Cool nice to know. Yea I was thinking about switching it back to yellow but really liking the blue. thanks
Old Nov 19, 2016 | 09:02 AM
Engine: 350 carb
I was able to check through my shed this morning and unfortunately I don't have the rpo codes��. Where would I be able to find out more info about my car.
Old Nov 19, 2016 | 09:24 AM
rarebmx's Avatar
Unfortunately the SPID contains all the RPO codes for the car. It is like the fingerprint for the car that contains the VIN. Without it, it is hard to document the way it came originally.
You might try & research the site to find out if Chevrolet history archives might be able to pull up something solely based on the VIN.
Old Nov 19, 2016 | 10:38 AM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Was that car originally yellow? If so, it confirms that it was an IROC-Z and would be the only yellow, '87 convertible I've ever seen
You may have a 1 of 1 there!
Good luck!
Old Nov 19, 2016 | 10:42 AM
rarebmx's Avatar
Good luck!
In 87 it could have started life as a Sport Coupe in yellow....? If you have an F (probably) or 8 as the 8th digit of the VIN TYEN it would confirm100% IROC.
Although all the IROC Anniversary cars were TBI as an automatic (only TPI was available with 5 spd). Your's being a 6th digit 2 car could have been a TPI or TBI.
Old Nov 19, 2016 | 11:20 AM
chazman's Avatar
Axle/Gears: BW 3.45
The non-IROC yellow was a sort of beige color, no?
This one looks like yellow-gold, or whatever the '85-'87 IROC-Z yellow was called.
Old Nov 19, 2016 | 02:10 PM
rarebmx's Avatar
True. You're right. I didn't think about the color variation.
That SPID sure would make it more desirable.
Old Nov 20, 2016 | 01:33 PM
Engine: 350 carb
Good luck!
I believe it was originally yellow. Trying to find out more about it
Engine: 350 carb
Does anyone know a website where I could find out more about it.
Old Nov 20, 2016 | 02:32 PM
Engine: 350 carb
Got some work done on the top today
New top pads
Old Nov 22, 2016 | 05:32 PM
Engine: 350 carb
Test fitting the new top
New rivets installed to the front bow
Old Nov 22, 2016 | 05:34 PM
Engine: 350 carb
Just got the New floors
Old Nov 23, 2016 | 04:26 PM
Engine: 350 carb
Installing the new top
Added some screw to help hold the back of the top to bow 5
Last part for today
Old Nov 24, 2016 | 11:09 AM
Engine: 350 carb
Old Nov 27, 2016 | 01:02 PM
Engine: 350 carb
New top still need some adjusting
Loving the way the new rear end looks
Old Nov 27, 2016 | 02:07 PM
rarebmx's Avatar
This is an ASC special edition 87. Wonder where the Special Edition tag ended up. I bet this car originally had yellow paint, tan interior & tan top.
This "cap" molding hid the holes for the original rear spoiler. A shame it's been so modified because it was the ONLY 1 in 87.
Old Nov 27, 2016 | 08:12 PM
Engine: 350 carb
Wow. Yea it had tan interior. I still have it.
Old Nov 27, 2016 | 08:15 PM
rarebmx's Avatar
I'm looking for 1987 Tan interior. I have nice 87 black interior. I have the same car as you. 87 convertible but mines originally black. Going to go tan interior.
Old Nov 27, 2016 | 08:19 PM
Engine: 350 carb
Nice. What color is your 87 originally.
Does your 87 have the spoiler piece too ?
Old Nov 27, 2016 | 08:22 PM
rarebmx's Avatar
Mine is factory triple black. Black interior, top & exterior
Old Dec 2, 2016 | 07:37 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Before we start jumping to a 1 of 1 conclusion, we need more information. Also, the LG4 was available in all models of 1987, including the IROC-Z.
If the dash doesn't have the special edition plate, or any markings for it, is the car an ASC conversion? If it isn't, then that would explain why ASC said they've never done a yellow Z28 or IROC-Z in 1987.
Old Dec 2, 2016 | 08:54 AM
rarebmx's Avatar
Those Special Edition plaques are easily removed & judging from this car it has had a few lives. It sure looks like an ASC conversion & sure looks yellow but a LONG way from how it ever came new. It would be quite a project to get it back to original as delivered new.
1 of 1 is almost trivial unless it was going back to original.
Once the floorboards are cut away it's going to be an even tougher car to bring back to original.
SPID missing is also a tough document to replace. We'll just say it's possible to be 1 of 1 but without two major pieces of the puzzle, it's just another Camaro.
Old Dec 23, 2016 | 08:48 PM
two-if-by-sea's Avatar
Car: 89 RS Vert, 89 Formula, 89 Bird
Engine: L03, TBI 350, none
Transmission: 700R4, 700R4, none
Axle/Gears: 3.42, 3.45, none
The core support, which also has yellow showing through, has a trim tag. Those tags stopped in '85.
Old Dec 23, 2016 | 09:00 PM
rarebmx's Avatar
GOOD EYE. The mystery continues
Old Dec 24, 2016 | 09:20 AM
Something is definitely askew here. It's not unusual for a car to have it's core replaced after an accident, but the fact that the original paint is such an obscure color, and that it matches what was under the seats, really makes me believe that the core support and trim tag are original.
I'm curious what the 10th digit of the VIN is. "H" would be 87, as the owner believes the car to be. "F" would be 1985, "E" would be 1984, "D" would be 1983, "C" would be 1982. The trim tag on the core support will have the last 6 digits of the VIN. That should match up to the last 6 of the VIN under the windshield. The VIN on the windshield should match the VIN on the title.
Old Feb 11, 2017 | 02:14 PM
Engine: 350 carb
Hey guys I was able to get some work done on my car today. And found this
QUOTE=two-if-by-sea;6100408]Something is definitely askew here. It's not unusual for a car to have it's core replaced after an accident, but the fact that the original paint is such an obscure color, and that it matches what was under the seats, really makes me believe that the core support and trim tag are original.
I'm curious what the 10th digit of the VIN is. "H" would be 87, as the owner believes the car to be. "F" would be 1985, "E" would be 1984, "D" would be 1983, "C" would be 1982. The trim tag on the core support will have the last 6 digits of the VIN. That should match up to the last 6 of the VIN under the windshield. The VIN on the windshield should match the VIN on the title.[/QUOTE]
Old Feb 11, 2017 | 02:19 PM
Engine: 350 carb
I also got new floors and a new driver side door.
Found some rust under the trim on the quarter panel. How should I go about fixing his ?
Old Feb 11, 2017 | 02:25 PM
Engine: 350 carb
Front end taken apart
Old Feb 11, 2017 | 02:32 PM
Engine: 350 carb
Here is a picture of radiator tag
