92 Z28 lq9/4l80e swap
Old Sep 21, 2017 | 04:55 PM
Formula Fore's Avatar
Alright so I decided to pick me up a 92 Z roller a few months back for a LS swap I've always liked the way they looked I just felt like the LS was the engine that this car was meant to have. This is gonna be my build thread, I've been studying up on the stickys here (which are extremely helpful to say the least) on LS swaps, so I feel like I've got most of it down, (except the wiring) but any help is much appreciated.
Alright here is a list, pictures, and prices that I paid for the parts that I have so far
1992 Z28 roller $1200
DBW/4l80e PCM and Harness $100
4th Gen oil pan w/pick up and windage tray $175
4th Gen gas tank $50
Spohn LS swap engine Mounts $90
4th Gen Water pump $120
4th Gen harmonic balancer $90
harmonic balancer bolt $15
LQ9 Motor $1000
machine work $450
flat top pistons $280
gasket kit $325
Torquer V4 cam $380
ls7 lifters with trays $125
Rod and Main bearings $70
4th Gen power steering pump w/bracket, alternator bracket, and LS6 intake $140 (this one was a steal of a deal)
Intake gasket $25 (kit didn't come with one)
Ls clamshell mounts $110
4th Gen 102 amp Alternator $75
DBW Throttle body $50
Maf $50
4th Gen Radiator $60 (broken)
Replacement radiator $100
K&N Air filter $30
Pick up tube O-ring (part #12557752) $12
4l80e Transmission W/flexplate $580
4l80e Crossmember $200
Starter $50
Fuel tank line & Fittings $200 (1000-06-01 -06AN female hose fitting X6) (640850 -06AN to 3/8 quick connect fitting X3) (10 ft of stainless braided hose) ( CT2-666X P 3/8 TEE fitting from home depot X1)
(800-159 doorman fuel repair kit from advanced auto X1) (800-153 fuel repair kit this is one flared closer and connects to fuel feed line and comes with a compression fitting from advanced auto X1)
Head bolts $75
LS2 Timing chain $150
EV1 injector pigtails $15
Fuseblock for Harness $50
241 Heads W/dual springs $325
Valve job $225
TSP pushrods $40
knock sensors $25
Melling high pressure oil pump $140
4l80e cooling lines W/adapters $115
DBW Pedal W/Harness $50
PCM Reflash $110
1 7/8 Speed Engineering Headers $320
Radiator fans $100
Cold air intake tubing $100
Radiator hoses $40
Thermostat $20
torque arm and SFC $400
C5 wheels $350
wheel spacers $100
transmission line and fittings $160
Harness rework $290
Main belt $30
4th gen brakes $50 (broken)
brake line $15
big brake upgrade kit $200
battery $140
power distribution block $30
catch can $60
Lokar transmission dipstick $100
engine dipstick $30
Torque converter bolts $10
02 Sensors $50
Fuel Tank filler neck $35
Spark Plug Wires $35
Radiator Fan Pigtails $20
Oil Port Adapter $10
ECT sensor $40
Driveshaft $140
Oil Filter 2 at $12 ea.
Coolant $20
Oil 10 quarts $60
Fuel Filter $7
Gas Cap $15
Heater Hoses $15
PCV hoses $15
Relays $5
Exhaust and mufflers $225
MPVI2 w/ credits $500
Exhaust manifold gaskets $20
Tune by Frost $300
Brake pads $60
Brake calipers X2 $120
Heater core $40
Total= $11,758
Old Sep 24, 2017 | 01:22 AM
EightFiveIroc's Avatar
Re: 92 Z28 lq9/4l80e swap
Oh man that's awesome! I'm starting my lq9/t56 (turbo) 85 iroc build in 2 weeks... I havnt don't nearly the amount of research I need to do. I've seen lq9's and t56's in my area.. just plan on buying the big stuff then get all the little stuff afterwards.. the iroc I have has a lt1 in it. gonna sell it and buy lq9 then purchase t56. I'm going to be following your build very closely.. im very interested. cant wait to hear more.
Old Sep 24, 2017 | 01:24 AM
I've been a member since aug 13th lol.. that was my 1st post.
Old Sep 25, 2017 | 02:25 PM
cardin555's Avatar
Car: 1987 camaro
Engine: Was a 2.8L v6
Transmission: 700-r4
I am in the process of doing an LQ4 and 4L80e swap into an 87 LT. I found Hooker-Holley have a cross member for the 4L80e but dont know anyone who has used it yet.
Old Sep 26, 2017 | 01:52 AM
picking up all the parts this Friday. hoping to do it all in under a month.
Old Sep 26, 2017 | 05:25 PM
toddoky's Avatar
The Hooker 3rd-gen crossmember is likely to give you installation issues if you use it with engine brackets other than the Hooker engine brackets it was designed for use with. This is because the Hooker engine brackets move the engine/transmission mating plane forward by approximately 5/8" from the stock SB Chevy position.
Old Sep 27, 2017 | 08:50 AM
Finally got some free time to get into the engine a couple days ago and it was just a complete mess. Ended up having water in the oil, spun bearings, rusted cylinders, bad lifters, hell you name it and it was either spun or rusted. So disssembled it all and took it to the machine shop yesterday, and to my surprise the block is still good to go, just needs a bore and hone i am however gonna need to go get a new crankshaft, piston tops, and rings. I wasn't planning on a complete rebuild, so I just have to add this to the ever expanding budget.
I'm just going start removing the harness from the car and strip it while I wait on the engine to return from the machine shop. I still need to read over pockets sticky a few more times though
Old Sep 28, 2017 | 09:58 PM
five7kid's Avatar
Car: 82 Berlinetta/57 Bel Air
Transmission: 4L80E/4L80E
Axle/Gears: 12B-3.73/9"-3.89
Have to say I've never seen an LS engine, either in person or in pictures, with that much rust inside it. Wow.
Since you have to get a new crank and pistons anyway, might as well make it a 4" stroke. New rods wouldn't be a bad idea while you're at it.
Having done both an LS1 4th gen plastic tank and kept the factory 3rd gen tank, I'd recommend selling the plastic tank and just getting a better in-tank fuel pump for the 3rd gen tank.
Old Sep 29, 2017 | 08:35 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Five,
Can you elaborate a little more? I have been researching this and most folks say it was a great swap, mostly due to the internal baffling and return-less set-up. Did any 3rd gen tank come with baffling? 1LE?
Old Sep 29, 2017 | 08:49 AM
Jeremy85's Avatar
Car: '85 Camaro
Engine: LG4
Transmission: 4L80E
Axle/Gears: 3.42:1
Five,
Not only the 1LE, but also all 92s, and possibly all 91s, afaik.
Old Sep 29, 2017 | 04:25 PM
Got the harness torn apart and hopefully done right for the swap gonna start pulling all the unnecessary stuff from the LS harness tomorrow
Old Sep 29, 2017 | 04:27 PM
yea it was pretty jacked up but these things can take a pretty solid beating thankfully. On the 4th gen tank i mostly went with it because I can find them for pretty cheap around here.
Old Oct 2, 2017 | 06:49 PM
Mirror Image's Avatar
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
My 91 firebird has a baffle in the tank
Old Oct 12, 2017 | 12:54 PM
Finally got the engine back from the machine shop today and it cleaned up nice bored .030 with some flat top pistons. Just ordered a Torquer V4 cam after talking to Chris from Texas speed, it should be in tomorrow afternoon so now it's time to start assembly on the engine
Old Oct 15, 2017 | 09:09 PM
Got the bottom end of the engine installed today
Old Oct 16, 2017 | 03:58 PM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
For a block that dirty, I'd be pretty upset if I paid a shop to clean it and they didn't even remove the oil gallery barbell.
Or maybe they did and you've simply reinstalled it?
Either way I'd recommend installing this is ANY LS build.
http://www.saccitycorvette.com/Billet-BarBell.html
2 other upgrades worth considering are a timing chain damper, and oil pump pickup girdle.
http://www.ebay.com/itm/LS-Engine-Oi...-/332202346994
Old Oct 18, 2017 | 12:33 AM
Lzamora's Avatar
What have you found so far for the member to use with the 4l80? I' currently doing the same just lq4 with 4l80 and trying to find the best option for it, I'd rather not have to make one if I don't have to even tho i work a metal shop 😅😅 I don' really have the time to make one at work
Old Oct 31, 2017 | 12:02 AM
haven't really gotten around to that part of the car yet been super busy at work lately and dealing with the engine is a task all in itself. I will let ya know when I do get there, though it might not be any time soon with the rate this is going haha.
Old Oct 31, 2017 | 12:05 AM
Lzamora's Avatar
I found a set up through Holley they sell a one, it' a bit pricey and I'm waiting for it to come in, if it works out well for me I'll let you know, I also used their motor mounts too as it's a whole series to be used together
Old Oct 31, 2017 | 12:07 AM
I'd appreciate that a ton I'll look for your word on it in a few thanks
Old Nov 11, 2017 | 07:57 PM
Ended up having to get different heads as the originals had a crack in them, so I found some 241 heads with dual springs, and some chrome moly pushrods for a pretty good deal, just had to send them off to get a valve job done. Got them installed today along with the rockers and push rods and a few other things. Just need to paint and hang the rest of the accessories and I'm done with the engine building portion of this project
Old Nov 11, 2017 | 08:06 PM
Lzamora's Avatar
Nice i just got mine in yesterday, trans would be in too but ran into a problem with my flexplate not fitting the torque converter I got so now I need to figure out what one i need.
Old Nov 11, 2017 | 08:09 PM
nice looking good does that holley Crossmember look like it's going to work?
Old Nov 21, 2017 | 07:36 AM
Got some more work done on the engine it's mostly put together accept for a few accessories, I also got the old fuel tank removed and installed the 4th gen tank was a pretty simple swap just needed to figure out wich fittings i needed and it bolted right in. So now I'm going to start really focusing on the LS harness and get it torn apart and put back together using pockets guides of course I'm not the best at wiring so this part might take me a while
Old Nov 21, 2017 | 08:13 AM
scooter's Avatar
I put 3 LS plastic tanks in and it is totally worth it, for the low fuel drivability alone is worth it,especially on an LS swap
Old Nov 21, 2017 | 08:18 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Nice job on the fuel tank. Which fittings did you use end up using to connect to the fourth gen sending unit?
Old Nov 21, 2017 | 08:33 AM
Thanks it took me a while to get it all figured out, and for the sending unit i used Russell quick connect 3/8 to -6AN part# 640850
i will update my price list with the part numbers and quantities of all the parts i used for the fuel tank to try and help anyone looking to swap in a 4th gen tank
Old Dec 1, 2017 | 02:07 PM
JAYDUBB's Avatar
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Watching this... Have you started a thread on your build?
Old Dec 23, 2017 | 10:11 AM
Been a while simce my last update but I got the alternator bracket hole drilled and tapped, the 4l80e connected, got the fittings, the PA racing Crossmember, some stainless line, and im getting ready to install this weekend. I'm also just about finished with the harness just got a few more wires to lengthen and shorten and connect the fuse block
Old Dec 28, 2017 | 02:41 PM
That harness is shaping up nicely.
Have you test fit the 4L80E yet? Curious what has to move to make it fit. (sorry, I didn't read the thread to find out if you mentioned already)
Old Jan 4, 2018 | 07:34 AM
thanks the harness has been a real pain but i think i got the hang of it now and as far as the 4l80e goes i personally haven't done a test fit yet i've been waiting on the weather to get a little warmer around here we Texans are not familiar with this 20 degree weather it is supposed to be warming up this weekend so hopefully i can get some more work done
Edit* Also sent in the PCM yesterday to get vats removed and a mail order tune put in I do have to say all of these little things really do start to add up, never in my life did i think i would ever spend this much money on fittings lol
Old Jan 4, 2018 | 01:27 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Looks awesome...
What do you have to do to get the sending unit to communicate with the gauge?
Old Jan 5, 2018 | 02:43 AM
Yeah, I know what you mean. There were a few things on my car that I felt cost a stupid amount of money for what I got out of it. The fuel system was one of those things.
Old Jan 7, 2018 | 09:18 PM
It was a great day to work on the car in the low 70s so I got around to installing the engine and tranny and it feels very satisfying just a few more odds and ends to the up and will be firing up soon
Old Jan 28, 2018 | 03:28 PM
Just an update I had to tear the harness apart again I didn't like the way it fit on the engine when it was installed so I'm re doing it
Old Feb 26, 2018 | 08:13 PM
Finally Finished up the painful process of wiring the harness today and got the lights working now im just waiting on a few pieces to be delivered and if all goes well the first start up attempt will be tomorrow
Old Feb 28, 2018 | 07:02 AM
cardin555's Avatar
Car: 1987 camaro
Awesome! Do you by chance have pics or details of how you did your fuse box set up?
Old Feb 28, 2018 | 08:09 AM
i used the stock 3rd gen fusebox following pockets guide for the harness I just need to set up a fuel pump and fan relay and that's about it
Old Apr 7, 2018 | 04:48 PM
Been upgrading a few things I ordered the BBU kit with the hubs and bracket for the 4th gen brakes and modified the spindle myself and I also got some C5 Y2Ks for a decent deal. Also got around to ordering the pieces for the cold air intake and it looks pretty good
Old Apr 8, 2018 | 09:24 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Transmission: Tremec TKO-600
looking good, can you give me some more details on the cold air intake? it looks good and i need to do mine on my lq9 soon.
Old Apr 8, 2018 | 11:46 AM
Thanks bud and heres the list of parts i used from intakehoses. com
1 4" 90 degree elbow
1 4" 45 degree elbow
1 4" aluminum X 12" in length
5 constant torque 4" clamps
Old Apr 8, 2018 | 11:59 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
wow thanks. first time i've heard of that site.
what filter did you end up using?
Old Apr 8, 2018 | 12:12 PM
skinny z's Avatar
Nice swap list.
Subscribed.
Old Apr 8, 2018 | 12:21 PM
no problem and im just running a K&N filter i found on eBay heres a link
https://www.ebay.com/itm/K-N-3-to-4-...BVptTy&vxp=mtr
Old Apr 8, 2018 | 12:22 PM
Originally Posted by skinny z
Nice swap list.
Subscribed.
Thanks bud i appreciate it
Old Apr 8, 2018 | 07:40 PM
a383z's Avatar
Thanks for posting the intake hose web site I was just debating what to do this week. At least one thing that will not need to be custom made.
Old Apr 8, 2018 | 11:13 PM
no problem glad i could help out
Old Apr 9, 2018 | 07:14 AM
scooter's Avatar
What are you boxing in the air filter with?
Old Apr 9, 2018 | 07:54 PM
rampageZ28's Avatar
if you don't mind me asking where did you purchase the BBU bracket from or did you make them yourself?
Old Apr 10, 2018 | 12:26 AM
I haven't even thought about that most of the ones I've seen are just like that one or have a hole cut and stuck through the bottom
