1992 RS 6.0 4L80E Swap
Old Aug 16, 2018 | 06:31 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Hey all, just wanted to get a thread going on my 92 LS swap to document some things and get some info/tips/input from you guys doing the same work. I've been at it a few months now so I'll upload a bunch of pictures and keep tracking progress from there. Any help/tips are appreciated!
Build is as follows
6.0 lq4 bored 0.030, ls6 intake, stock crank, eagle forged rods, mahle forged pistons 11:1, custom grind comp cam, factory 243 heads with manley 0.660 dual valve spring kit, trunion upgrade with stock rockers, walbro 255 fuel pump, corvette regulator
4L80E with transgo shift kit
All motor mounts / crossmember / exhaust will he holley's LS swap system
Old Aug 16, 2018 | 06:35 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Re: 1992 RS 6.0 4L80E Swap
donor motor, lq4 4l80e 2wd
harness as taken out from donor truck
and cleaned up / ready for interface with thirdgen harness. found a great writeup over at http://lt1swap.com/2004vortec_pcm.htm
this site is a HUGE help in determining pinouts and all things wiring related. I just did the normal stuff (ac delete, emmissions delete, yadda yadda)
Old Aug 16, 2018 | 06:40 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
out with the old 350 TBI 700r4 setup and cleaning begins
Old Aug 16, 2018 | 06:43 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
wanted to get the engine bay painted while everything was out. went with a sherwin williams artic white single stage. turned out great, was very pleased with this being my first actual automotive (not rattlecan) painting project.
Old Aug 16, 2018 | 06:50 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
now onto the undercarriage. I ended up going with Eastwoods Underbody Rust Encapsulator prodcut after much debate with por15. I'm happy with the result, went on easy and looks great. Time will tell on durability. Took about 6 cans to do the whole undercarriage and k member
Old Aug 16, 2018 | 06:55 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
onto the fuel system. ended up going with a walbro 255 pump, corvette filter/regulator combo with -6an adapters, and running all new -6an PTFE line from the factory fittings to the fuel rail. Had all lines made up at the local hydraulic shop (this is the way to go people! don't mess with cutting your own lines and putting fittings on. I was in and out in 30 mins and price was just a little higher than if I bought hose and hose ends myself)
Old Aug 16, 2018 | 06:57 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
holleys ls adapter motor mounts and crossmember mocked up. quality and fitment have been great so far
Old Aug 16, 2018 | 06:59 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
rear end back in the car. went with a founders panhard relocation kit to make room for the future 2.5" true duals. Also machine shop sneak peak
Old Aug 16, 2018 | 07:02 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
aux trans cooler b&m 70266 mounted. this is about the biggest cooler i could seem to fit without too much modification. Also chopped the ears off of the 4l80e to make room for install
Old Aug 16, 2018 | 07:04 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
thirdgen c100 harness before and after prep for swap. i followed pocket's guide on howto and was great. thanks pocket!
Old Aug 17, 2018 | 02:37 PM
dmccain's Avatar
Gonna b nice!
Old Aug 20, 2018 | 05:43 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
got the trans temp gauge mounted up
Old Aug 23, 2018 | 12:44 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Transmission: Tremec TKO-600
looking good, best thing i did to my car was the lq9 swap!
Old Aug 23, 2018 | 02:27 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
your car is coming along nicely and the engine bay turned out great.
your swap is almost an exact copy of what i'm currently doing on my 1984 Trans Am. it's slow going, but i've been making some good progress this summer. i'm most nervous about the wiring. i want to modify the harness myself to save a good chunk of money, but worried i'll screw something up.
here's a link to my build thread: https://www.thirdgen.org/forums/memb...-am-build.html
Old Aug 23, 2018 | 05:13 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
thanks to you both! ive seen your build thread batman, very thorough! will definitely be worth the wait
Old Sep 16, 2018 | 09:31 AM
vwdave's Avatar
I see that 1.8t VW head in the background there.
Old Oct 14, 2018 | 02:24 PM
roysatikas's Avatar
Car: 91 RS
Engine: 4 bolt 350, .060 over
Transmission: 700R-4
i cannot begin to express my reverence for you! Harness on the carpeted living room floor! You are my HERO!!!
Old Oct 14, 2018 | 03:45 PM
When you have the car sitting on the ground you"ll want to verify that the Panhard bar is still pretty close to level. Most of the time when you lower the body side mount to make room for the exhaust tubing the Panhard bar ends up angled. There are axle side brackets that UMI makes to correct this if it is angled.
I think single stage in the Arctic white for an engine bay was a good choice. I went with single stage DuPont Arctic white for the underside of my hood and was actually impressed with how it turned out.
Old Oct 20, 2018 | 03:51 PM
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
You should review the B&M installation .pdf. https://static.summitracing.com/glob...er_techdoc.pdf They don't recommend the installation you have.
Old Oct 20, 2018 | 10:33 PM
roysatikas's Avatar
Car: 91 RS
Thanks but that link just discusses trans coolers?
Roy
Old Oct 21, 2018 | 12:18 AM
92BLKL98's Avatar
Roy
The top of the page shows correct cooler orientation (fittings on the top or sides). His orientation may cause issues with the system cooling efficiency.
From the .pdf: It is not recommended to mount the cooler with the fittings pointing down as this may create an air pocket in the cooler resulting in reduced cooling efficiency. When mounting the cooler with the fittings on the right or left side, the lower fitting must be the inlet with the top fitting routing the fluid back to the transmission
Old Oct 21, 2018 | 06:10 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
awesome! thanks for that, must have missed it during installation. I will correct to proper orientation. I should have some more updates on the build this week to post.
Old Oct 24, 2018 | 07:09 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
few more updates. had a friend let me help with assembly. shortblock is together, hopefully more progress next week!
Old Oct 24, 2018 | 11:44 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
The 4l80e sure is a monster isn't it?
I didn't see anything about a converter so I thought I would chime a suggestion. A converter will make/break the entire swap, as dumb as it sounds, so I felt it necessary to bring this up.
I recommend a high efficiency 9.5" lockup from reputable company such as Yank.
What else can I say? I was able to use a stock Camaro shifter for 4l80e which feels more reliable and simple than anything aftermarket. And cheaper. Just throwing that out there.
HPtuners was also a great investment. Almost immediately made the $$ back unlocking other people's ECU with it. Highly recommend tuning yourself. It will also give you the power of diagnosis from the driver seat. i.e. scanner reads trans temp, wideband info, and logs everything, very handy.
Old Oct 25, 2018 | 12:05 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
I'll be using a 3500 stall 10.5" billet single disc lockup from Pat's performance converters (local company). Should work out great. For the shifter, are you using factory 3rd gen shifter? If so how to you adapt the linkage to mount to the 4l80e trans? Pics would be great
Old Oct 25, 2018 | 01:45 PM
battmann's Avatar
i used a B&M megashifter made for a thirdgen with a 4L80E i installed in a 1972 camaro. it worked perfect so i suspect the stock 700R4 shifter cable and bracket from a thirdgen may work with the 4L80E. that's what i intended to do with my swap, but i haven't got that far yet to try it out.
Old Oct 25, 2018 | 04:11 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
Here are some pics from the build. I think its a 4th gen shifter, probably a v6 camaro unit.
Slotted the bolt holes for the bracket as pictured, bracket is either from 4l80e stock unit or the 4l60e unit.
The shifter 'ball' (linkage on the trans) was the large one also from V6 I believe. I went to JY and grabbed a variety but the large one fit the shifter so...
personally I do not like aftermarket shifters for a variety of reasons. I've owned in the past and never really fond of the ratchet style (more work) or anything that looks fancy/flashy (you can look inside the car and say 'ah, its modified') this way with the OEM shifter nobody can tell you've done anything.
No reason to touch the shifter while driving- I prefer let it shift by itself because A: less chance of human error and B: less fuss, more concentration on the road
With HP tuners you can configure two different shift maps. So if I want it to hold 1st longer or shift harder or not downshift sometimes, instead of downshifting the trans I just smack the momentary switch and it flips to another map with all new shift MPH and pressures/torque mgmnt.
Old Oct 28, 2018 | 03:55 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
had some time to modify the factory truck lq4 dbw gas pedal to fit. I originally purchased the mounting bracket made by Hawks thinking it would make things easy. Turns out their adapter is not for the truck pedals, so modifying was the only way to go. pics to come
Old Nov 3, 2018 | 09:50 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Pics of truck dbw gas pedal mounted after modification. Was able to use the factory third gen gas pedal pad to keep things matching.
Old Nov 3, 2018 | 10:20 PM
92BLKL98's Avatar
Oh I was looking over your trans cooler again, did your car have the X braces on the radiator opening in the core support and if so what were you doing about them? My Z has them but I wonder if they are really a big deal?
Old Nov 4, 2018 | 09:01 AM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
I decided to remove them. I also had to remove some of the air deflecting plastic that surrounded the cross braces to fit the trans cooler. Not sure how much they were doing, but I have a wonderbar installed and will have a strut tower brace also, which should really stiffen the front up. Not really worried about the original cross braces.
Old Nov 5, 2018 | 09:46 AM
UKLS3GTA's Avatar
used a standard b&m megashifter on my 4L85E, the fittings bolt straight upto the oilpan bolts. so would think standard 700R4 cable and bracket would fit (already had megashifter in car with 700R4 before swap)
Old Nov 5, 2018 | 11:02 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Nice progress... its amazing how quickly an engine swap turns into a mini-restoration I.E. see my thread on my LS1/t56 swap
Old Nov 14, 2018 | 12:56 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
got the motor together!
Old Nov 14, 2018 | 12:59 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
also decided to rework the lq4 wiring harness to allow the pcm to be mounted in factory location. the lq4 has the pcm mounted in the drivers side front engine bay, so quite a bit of wire needed to be added to get enough length to follow the factory harness routing around the passenger fender and under the dash. it took forever but end result should be nice
Old Nov 22, 2018 | 09:24 AM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Old Nov 22, 2018 | 10:33 AM
toddoky's Avatar
Good work, everything looks nice and tidy.
Old Nov 25, 2018 | 06:28 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
progress continues! lots accomplished this weekend. working on wiring now, but here are a few shots
Old Nov 27, 2018 | 04:48 AM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
what accessary brackets are you using ?
Old Nov 27, 2018 | 05:43 AM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
https://www.dirtydingo.com/shop/prod...oducts_id=1370
this kit allows for a truck balancer / truck alternator / truck ps pump to all be reused. I went with a ls1 style water pump, so I also had to purchase their water pump spacers to push the pump out to align with the truck belt arrangement. Overall fitment and quality is excellent. No complaints at all. Even allows for factory 3rd gen PS pressure hose to be reused without modification.
Old Nov 27, 2018 | 10:18 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
thanks
Old Dec 2, 2018 | 07:46 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
few more updates:
wiring is pretty much finished. pcm mouting, engine shots, and racetronix hotwire kit shown below
Old Dec 3, 2018 | 01:21 AM
You really don't want steel braided fuel line rubbing a wire. That s*** cuts everything and electricity grounds to metal. That's a recipe for car going up in flames.
Old Dec 3, 2018 | 01:34 AM
And if that is a fuse then it belongs in the engine bay close to the power source, not all the way at the back of the car. The fuse can't protect the wire from shorting between the battery and the fuse.
Old Dec 3, 2018 | 07:22 AM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
thats a racetronix premade fuel pump hotwire harness. the fuse holder is about 1" off of where the main power wire connects to the alternator post. As for the harness being tied to the braided line, I see you concern. However car going into flames may be a bit extreme. I will move it over to the soft fuel line to be safe. BTW, I have used your build thread as a reference throughout my project. Thanks for that!
Old Dec 3, 2018 | 07:24 AM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Old Dec 3, 2018 | 10:06 AM
I had a Corvette that caught fire this way. Fuel braiding rubbed through wire, wire sparked to fuel line and caused a leak, fuel caught fire from sparks. Wouldn't want to see that happen to you.
Old Dec 3, 2018 | 11:41 AM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
wow! will most definitely move the wiring now!
Old Dec 3, 2018 | 07:30 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
toddoky,
you our are the Holley engineer right? Do you guys have any ideas for using the third gen shifter bracket/cable with the 4l80e? Ive got a few ideas on how to make it work, wondering if you had any input.
Old Dec 3, 2018 | 08:45 PM
dixiebandit69's Avatar
Car: '89 Firebird Formula
Engine: TBI 305
Axle/Gears: 10-bolt, 3.42s, Torsen diff.
Can you please post some more pictures, or at least describe more what you had to do to get the truck pedal to fit?
I'm doing a similar swap (2004 4.8), and I'm wondering how I'm going to get the pedal to fit in the cab, and still feel right when I drive.
