[NJ] LT1 Intake Conversion, You Finish It....
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
This is the second LT1 intake conversion I was going to do that I pulled from the yard, but then I decided to go a completely different direction with the engine I am running and just stopped what I was doing with it. This is a machinist and tig welder special, the LT1 intake was already cut in the back, and a TPI distributor hole was also cut from a donor intake manifold for it, so it is just the matter of smoothing it all down, fitting it, and tig welding it in. That, and once the side bolt holes are redone properly, you can have yourself the beginning of an LT1 intake for your SBC for very cheap. Twenty five dollars for what you see in the picture (not shipped), if you need it shipped then we'll figure out shipping if need be. Again, it needs to be finished properly, but any decent machinist and tig welder can have it done in a few hours. Just fit and weld in the distributor hole piece, fill the cylinder head bolt holes then re-drill them for whichever heads your running. Thanks guys...
- Rob
- Rob
Car: 87 Iroc 5.7,67 SS Camaro,90 Formula
Engine: 355 AFR Superram LPE 219
Transmission: 700r4 3000 stall 4spd 5 spd
Re: LT1 Intake Conversion, You Finish It....
ill take it where in nj are you im in freehold 732 2991140 ask 4 chris cfin1974@yahoo.com
- Rob
9192camaro
16
Feb 3, 2019 12:21 AM
