Parting out 1992 formula 5.0tpi 5 speed 3.42 disk rear car
Old Oct 8, 2016 | 10:11 AM
89irocz355's Avatar
Car: 89 iroc/90 iroc conv./06 ram
Axle/Gears: 3.27/3.27/3.91
Parting whole car. 81,000 original miles.
Speed density engine harness 220 shipped
Computer 110 shipped
Ws6 steering box 80 shipped
Much more
Attached Thumbnails Parting out 1992 formula 5.0tpi 5 speed 3.42 disk rear car-20161008_095220.jpg   Parting out 1992 formula 5.0tpi 5 speed 3.42 disk rear car-20161008_095037.jpg
Old Oct 8, 2016 | 11:12 AM
XrayTedd's Avatar
Car: 87 K5 Blazer
Engine: 355 TPI SD
Axle/Gears: Corp 10 Bolt 3.73
Re: Parting out 1992 formula 5.0tpi 5 speed 3.42 disk rear car
I'd be interested in the ac bracket and the alt bracket and the supporting rods for them.
Old Oct 9, 2016 | 11:04 AM
rosco88ta's Avatar
Car: 88 Trans Am
Engine: 355 c.i.
Transmission: 5 spd.
Axle/Gears: 3:42s
I'm looking for all the emission controls smog pump, control valve and air tubes Please let me know. Thanx.
Old Oct 9, 2016 | 03:29 PM
Ryan22's Avatar
I sent you an email reply.
Thx-
Old Oct 9, 2016 | 06:11 PM
91chevyz28's Avatar
Car: 1991 Camaro Z28
Transmission: 5 speed
Axle/Gears: alunimum drum limited slip 3.08
How much for the rear
Old Oct 9, 2016 | 06:17 PM
89irocz355's Avatar
300 picked up
Old Oct 9, 2016 | 08:52 PM
91chevyz28's Avatar
Originally Posted by 89irocz355
300 picked up
I also would like the plastic gear from the trans so my speedo would be correct when I swap out the rear. Thanks.
Old Oct 9, 2016 | 08:56 PM
89irocz355's Avatar
That's something you can buy. I am selling tranny and have to include that with tranny
Old Oct 10, 2016 | 12:13 AM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
How much for the shifter? Shipped 83709
Old Oct 10, 2016 | 12:59 AM
yamahondarider's Avatar
Want a title? Post!
Car: 1988 Trans Am GTA
PM sent
Old Oct 10, 2016 | 07:00 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Just wondering, why is this car being parted out?
Old Oct 10, 2016 | 07:01 AM
89irocz355's Avatar
No paperwork
Old Oct 10, 2016 | 07:06 AM
TTOP350's Avatar
Bummer, how hard is it to get a title there?
Old Oct 11, 2016 | 09:42 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
He lives in the peoples republik, where if you don't have a title they cart you off to the gulag.
He could have sold it to me, and I could have 'cleaned' it as NH is very good about that, but I'm already in the doghouse with the wife. So I'm just getting the bumpers off it haha
It does look like a nice car. Better than the one I started with. Very sad.
-- Joe
Old Oct 11, 2016 | 10:22 AM
prossi's Avatar
is the trans available? how much.. just need trans no bellhousing
Old Oct 11, 2016 | 08:41 PM
89irocz355's Avatar
Sold
Old Dec 30, 2016 | 08:24 AM
michael's Avatar
Car: 1991 Formula
Engine: 6.2 383 TPIS Miniram
Axle/Gears: Moser 9" 4.11
Could really use that harness. The 5.0 and 5.7 are the same harness as long as they are MAP correct? What all would you be including with it? The relays etc on the firewall? Any broken tabs/eyes or anything?
Have the hvac harness from under hood to inside still available also? Squirrels got at both pass and drivers side at the firewall right before Christmas. Merry f@#$@#$@ Christmas to us. :-(
Old Dec 30, 2016 | 11:49 AM
Biledriver's Avatar
Car: 87 firebird 86 c10 90 mustang
Engine: 383 sbc
Transmission: 97 t56
Axle/Gears: Moser 12 bolt 3.73
Does it have a nice center console?
Old Jan 1, 2017 | 07:47 PM
TORN's Avatar
Car: 88 IROC-Z
Engine: 6.9L TPI(FIRST) 421ci
Axle/Gears: Ford 9" Eaton truetrac 3.50
How much for the positive battery cable?
Old Jan 7, 2017 | 07:14 AM
89irocz355's Avatar
40 shipped
Old Jan 7, 2017 | 11:28 AM
ThirdGen1984's Avatar
Car: 1984 F41 Camaro
Engine: LC1 V6 2.8L
Transmission: 4 Speed Auto
Does the steering box have any play? Will it replace my stock steering box that is loose?
Old Jan 7, 2017 | 11:35 AM
Fireslash's Avatar
A/c condenser?
Old Jan 8, 2017 | 11:04 PM
Bald_eagle_machine's Avatar
Car: 1988 Trans am GTA
Engine: L98 350 TPI
Axle/Gears: Factory 9 bolt w/disc brakes
Interested in the tranny torque arm mount. Curious as to if the NWC and WC t5 mounts are any different. I have a NWC t5 myself. And need this bracket. Thanks in advance.
Old Jan 9, 2017 | 08:43 AM
TTOP350's Avatar
Same
Old Jan 9, 2017 | 07:19 PM
89irocz355's Avatar
Steering box is tight. The car only had 81,000 miles
Old Jan 22, 2017 | 05:39 PM
Longshot08's Avatar
Axle/Gears: Stock
pm sent
Old Jan 23, 2017 | 10:09 AM
Steve Quinn's Avatar
Car: 1990 Camaro IROCZ
Axle/Gears: 3.45
Do you have the t5 trans crossmember?
Old Jan 26, 2017 | 02:29 PM
89irocz355's Avatar
I do. 45 shipped
Attached Thumbnails Parting out 1992 formula 5.0tpi 5 speed 3.42 disk rear car-20170123_113142.jpg
Old Feb 3, 2017 | 08:57 PM
Anti-Venom's Avatar
Car: '89 Formula WS6
Transmission: 700r4/T56
Axle/Gears: BW 3.23
I'm interested in the mounting bracket and bolts for the clutch resevoir and the map sensor, bracket, and vacuum elbow.
Also how is the 5spd console plate and shifting boot? Is it in good condition?
Old Feb 5, 2017 | 10:52 AM
LS2Swapped92's Avatar
Interested in ebrake cable from handle into tunnel
Pic from tunnel please so I can see the connection
Thank you
Old Feb 7, 2017 | 12:49 PM
Dskeezy16's Avatar
Car: 1985 Firebird Trans Am
Engine: ls1
Transmission: t56
Axle/Gears: 8.8 Ford 3:73's
PM Sent.
Old Feb 8, 2017 | 07:36 PM
SnotRkt's Avatar
Car: 1986 Trans Am
Engine: 350 sbc
How much for gauge cluster?
Old Feb 9, 2017 | 01:17 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Interested in the rear end, would be a pretty decent drive since I'm on the coast of Connecticut. posi rear correct?
Old Feb 9, 2017 | 01:21 PM
89irocz355's Avatar
342 is long gone. I have a 91 trans am now I'm stripping with a pbr 3 23 disk posi
Old Feb 12, 2017 | 01:31 AM
Dakinebudz808's Avatar
Want a title? Post!
Do you still have the quic ratio steering box?
Old Feb 12, 2017 | 04:43 AM
89irocz355's Avatar
Yes I do
Old Feb 12, 2017 | 04:44 AM
89irocz355's Avatar
70 shipped
Old Feb 23, 2017 | 07:10 AM
z91bowtie1's Avatar
Car: 91 Z28 convertible
Engine: 96 LT1 5.7
Transmission: t5 5speed
Axle/Gears: 3.73 gears
Hi do you still have the rear and if you do where are you located. Thanks
Old Feb 24, 2017 | 10:53 AM
bigcatlett's Avatar
Car: 92 Camaro RS
Engine: 5.7 LT1 (Bored 95 Corvette Block)
Transmission: T56 - 6 Speed
Axle/Gears: 4th gen posi with 3.42 gears
do you still have the engine?
Old Feb 27, 2017 | 06:37 PM
fbodyguy86's Avatar
Car: 92 camaro rs
i am looking for the intake and up plus harness if still avail
how much are you asking for
thanks
george
Old Feb 28, 2017 | 06:23 AM
TTOP350's Avatar
Do you have the factory chip for this car?
Old Mar 2, 2017 | 01:37 AM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
The lower half of the HVAC box that's in the Eng bay, is it unbroken and how much?
Sent from my electronic leash.
Old Mar 2, 2017 | 03:41 AM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Still have the proportioning valve?
Old Mar 4, 2017 | 08:10 AM
Chuck84TA's Avatar
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
Do you still have the rear sway bar? How big is it?
Chuck
Old Mar 8, 2017 | 11:52 AM
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
does it have N10 dual cats?
Old Mar 8, 2017 | 06:00 PM
Mikes86transam's Avatar
Car: 86 Trans AM LG4 5spd
Do you have the flywheel dust shield cover for the T5? I'm in need of one. Please let me know. Thanks
mgm1884
Nov 30, 2016 09:34 AM
mgm1884
Sep 1, 2016 01:48 PM
ZachSRP
Aug 29, 2016 10:56 PM
mecham84
Aug 15, 2016 06:45 PM
19irocz85
Aug 13, 2016 12:15 PM
