"Later 86/ Early 87" 305 TPI 5 speed Trans Am
Car: 1987 Trans AM WS6
Transmission: TH700R4 Stock
Axle/Gears: 3.08 LSD
Hello guys
I got an early 87 model 305 5 speed Trans Am (sadly now a 700r4) with 3.08 rear end.
The previous owner swapped an 89 block and an 87 700r4 "early 87 without the rainbow").
My car was built in 1986 but I read that no LB9 86 5 speed car were produced.
My car is a bright red/ silver model with black spoiler and red chicken badge on the rear tail lights. She got T-tops
I don't know what cam is in the car but i guess they put the L98 cam that was in the first block in the 89 one.
The car was sold in Europe and registered in FEB 87 but is an USA import model. The 3rd stop is located in the spoiler.
What do you think about it? Is it a rare car?
How do I know if I got the L98 cam?
Thank you in advance
Car: 1989 Trans Am GTA
Engine: 5.7L 350 TPI (Deleted Cats)
Axle/Gears: Original 3.27
Re: "Later 86/ Early 87" 305 TPI 5 speed Trans Am
As far as i know there is no way to tell the L98 cam unless you take it out. Have you tried looking up the casting numbers on the block?
The block suffix is ATF
The heads are 081
The heads are 081
Well it is a 305.. but to find out the cam i would assume it needs to be removed.
