Need help tightening transmission lines to 700r4
Old 04-22-2024, 10:15 AM
BlackFireHawk's Avatar
Car: 1989 Firebird Formula
Engine: 5.7 tpi
Bought an 89 Formula and was told the trans was replaced. Found it was leaking trans fluid really bad and put the car up and founds the cooler lines are soaked. Assuming there not tight eough I tried to tightness them but can't get a grip on them and there's very little room.
is the trick till tightening these ?
useing 1/2" wrench
Old 04-23-2024, 09:00 AM
roadthrills's Avatar
Car: 1982 MSE, 1988 S10 Blazer
Engine: 305 in both!
Transmission: 200c / Th700r4
Axle/Gears: 3:73 / 3.42
Re: Need help tightening transmission lines to 700r4
They make flex head ratcheting line wrenches. Makes it MUCH easier.
Old 04-23-2024, 09:09 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
U may have to remove the trans dipstick/filler tube & plug that oriface then use the tubing wrenches to tighten the lines.
Old 04-23-2024, 09:09 PM
I have also cut the lines with a tubing cutter in an easy to access spot to R&R a trans, then reattach using a compression union. That way you can get at those fittings BEFORE you stick it back up in the car.
Old 04-24-2024, 05:52 AM
exiled350's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 427ci Gen 1 Small Block
Axle/Gears: Strange60 4.10 Eaton Truetrac
Line wrench crows foot.
Old 04-24-2024, 09:24 AM
72buickgs's Avatar
Car: 1984 Trans AM
I have a leak of tranny fluid. Started a couple months ago. When I get my T/A back today, I will attempt to diagnose source. I am guessing that it is the o-ring on the tranny fluid filler tube at the base. Had that problem with the TH350 in my 1972 Buick GS (sold) many years ago.
Old 04-24-2024, 12:29 PM
Common drip areas are filler tube, shift shaft seal, speedo cable seal, and pan gasket.....ESPECIALLY if it's an old cork gasket, they rot. Then after that is rear output seal, front seal, and pump gasket/o'ring.
BlackFireHawk
04-22-2024 10:44 PM
BuiltZ28
08-27-2008 09:06 AM
Quick Reply: Need help tightening transmission lines to 700r4
