DFI and ECM Discuss all aspects of DFI (Digital Fuel Injection), ECMs (Electronic Control Module), scanners, and diagnostic equipment. Fine tune your Third Gen computer system for top performance.
Does rear gear change require PROM update?
Old Today | 04:04 PM
Thirdgen4me2's Avatar
Car: 91 Z28 / 86 Iroc
Engine: L98 / TPI 305
Transmission: 700r4 / 700r4
Axle/Gears: 3.23 / 2.77?
I have a 1991 5.7 tpi and was wondering if changing the 3:23 rear to 3:42 and dont know if this requires a prom update?
Old Today | 04:06 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Does rear gear change require PROM update?
No it doesn’t but you might want to change Vss gears or use a Dakota digital sgi-100 bt to calibrate the speedometer signal. If automatic transmission and gear swap and don’t calibrate the Vss signal tcc lockup will occur at a different speed.
dwillis
Oct 31, 2005 10:38 PM
CaliCamaroRS
DIY PROM
Nov 15, 2002 08:34 AM
Pete87TA
Sep 12, 2002 11:51 AM
MouseCamaro305
May 2, 2001 10:40 AM
