most gear i can use?
Old Oct 31, 2005 | 10:07 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
whats the most gear ratio i can go with without having to change my vss...92...305..T-5...supposed to be a 3.08 peg leg
Old Oct 31, 2005 | 10:16 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Any ratio change means you either have to change your plastic gear on the VSS or change your VSS constant in the PROM (if you prom tune)
Old Oct 31, 2005 | 10:32 PM
dwillis's Avatar
Axle/Gears: 3:08
i would really like to do my own prom but i dont feel confident enough and dont know what i need to do it....thanks
Old Oct 31, 2005 | 10:37 PM
dwillis's Avatar
Axle/Gears: 3:08
does anyone know what plastic gear to use for a 3.43 gear
Old Oct 31, 2005 | 10:38 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Theirs a good little chart in the tech articles off of the TGO main site, Shows what colored gears you need to match up with the rear end gearing. I believe it also gives the part #s for them too.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
