Using a 4x4 6L80 From a Chevy 2500
Old Yesterday | 08:30 PM
603NHCamaro's Avatar
Car: 1992 Chevrolet Camaro Z28
Engine: V8, 305
Hey everyone,
I recently bought a 1992 Camaro Z28 with a 305 (TPI) V8 and an 700R4 automatic transmission. This is my first build, so I’m still learning as I go.
My plan is to do an LS swap and pair it with a 6L80 transmission. I’ve been researching different options and wanted to ask if anyone here has used a 4x4 version of the 6L80 and modified it to fit in a third gen F-body.
If so, is it worth it and what all was involved? Tail housing swap, output shaft changes, driveshaft issues, crossmember mods, tuning, or anything else I should know before going that route?
Any advice, build threads, or lessons learned would be greatly appreciated. Thanks!
Old Today | 02:59 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Re: Using a 4x4 6L80 From a Chevy 2500
Here is "any advice": Leave the car alone. Make that TPI 305 run as good as you can, keep the 700R4, and just drive the car. Enjoy it for what it is: a cool piece of 1980s history.
Old Today | 09:44 AM
Pocket's Avatar
Car: 91 Trans Am
Automatic 4x4 to RWD conversions require a complete teardown to replace the output shaft and then use a RWD tail housing
The output shaft is one of the first pieces installed into a trans case
Same for 700R4, 4L60, 4L60E, 4L80E etc
If you're rebuilding the trans when going in, sure it's fine for a core as long as the trans shop can source the missing pcs
DIY, I don't recommend it
Also, the 6spd case is enormous compared to the earlier 4 spd autos. Controller options are also limited, so it's not a great option for 3rd gen LS swaps
Old Today | 12:28 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Test drive a 2007 truck and a mostly identical 2009. You'll be able to decide if the 6 is what you want. My vote involved buying an E38 5.3 6L80 truck years back because it wasn't a 4L60.
As with all swaps, the closer it is to a complete production power train, the more likely it will drive nicely like one.
454yoppa
May 16, 2023 03:00 PM
cheftim13
Oct 2, 2016 09:48 PM
Area51
Oct 24, 2011 09:22 AM
89 T/A
Fabrication
Jul 3, 2007 06:33 AM
jess
May 30, 2003 07:51 AM
