MAX AC not working
Old Jun 18, 2026 | 07:32 AM
rymanrph's Avatar
Car: '88 IROC
MAX AC not working
I have a situation where only the Max AC function doesn't work. It's my understanding that this simply controls where the air intake comes from, but when I move the slider to that position, nothing happens. The blower doesn't turn on at all; it's like it's still in the off position. I can hear a very slight vacuum noise, but nothing else. All of my other HVAC functions work. Regular AC, bi-level, vent, heat, and defrost all seem to work as intended. The blower motor fan speeds appear to be all different - just nothing happens when I try to use max AC. Last year I spent a lot of time (and money) getting the AC to work and at one point max ac did work, but I don't know what has changed. Any ideas?
Old Jun 18, 2026 | 08:18 AM
goldandblue's Avatar
Car: 1988 GTA
Re: MAX AC not working
The relay on the right in this picture. Just had the same thing happen. I had trouble finding the same one with the correct pin layout so I got this one. It was ultima brand from oriellys.
Old Jun 18, 2026 | 08:20 AM
rymanrph's Avatar
Car: '88 IROC
Fantastic - I'll take a look at it. Thanks for the info!
Old Jun 18, 2026 | 08:24 AM
Car: 1988 GTA
Ultima part number rlyu0176
Old Jun 18, 2026 | 08:32 AM
rymanrph's Avatar
Car: '88 IROC
Is this the relay for the blower motor in general? If so, are there separate pins for different functions?
Old Jun 18, 2026 | 08:41 AM
Car: 1988 GTA
I'm not sure. I had a hell of a time finding a replacement.
Old Jun 18, 2026 | 12:22 PM
dabomb6608's Avatar
Car: 86 Trans Am/85 K5 Jimmy
Engine: 406 FIRST/350 TPI
Transmission: TKO 600/700R4
Axle/Gears: 9Bolt/10Bolt front & back
If his fan works in all other modes except Max AC, the relay is functioning fine. The HVAC control uses the same fan relay/speed control in all modes. Sounds to me if nothing happens except the vacuum motor being actuated in Max AC then it is the HVAC control itself having a issue.
Old Jun 18, 2026 | 01:18 PM
Car: 1988 GTA
All I know is that when I swapped that relay mine started working on max ac when it did not before. Now, if it happens to be a wire jiggle of something in the swap out that actually cause it to work, I don’t know.
Old Jun 18, 2026 | 01:37 PM
dabomb6608's Avatar
The relay shown is the high speed fan relay. It only controls high speed function of the blower motor.
Max AC compared to AC mode recirculates air from cabin. That is the only difference between the two. Which is controlled by the vacuum actuator on the flap door. Electronically it is the same for both modes. Sends 12v on its path through the various AC components to the clutch and then sends 12v through either the orange wire when in high fan setting or the other wires for 1/4 speed, 1/2 speed, 3/4 speed that goes to the fan speed resistors.
Old Jun 18, 2026 | 01:45 PM
Car: 1988 GTA
That’s fair enough and I’m not arguing with you. All I can say is that I could have fan on high with the selector on norm and it would blow away. If I left fan on high and selected max ac the blowing would cease. Changed out that relay and it started working. Could have 100% been a cawinkidink as I was working right next to the blower resistor. Do you think that is more likely what happened?
Old Jun 18, 2026 | 01:55 PM
rymanrph's Avatar
Car: '88 IROC
One thing I have not tried is different fan speeds for Max AC. Usually, I've just got it on high all the time. I'm curious if having it set at a lower speed would change the results. I suppose it's possible that the "high speed" I'm seeing is not actually high, but I would assume that it wouldn't work in that setting, not just spin at a lower speed.
Old Jun 18, 2026 | 06:28 PM
rymanrph's Avatar
Car: '88 IROC
Different speeds didn't change anything. My setup is different. I don't have the same relay setup.
My wiring is just slightly different because of my LS swap, but the majority of the HVAC wiring is untouched.
Old Jun 18, 2026 | 06:35 PM
Car: 1988 GTA
The small relay there in the pic is your blower motor relay. Perhaps try that.
86White_T/A305
Nov 23, 2012 08:01 AM
90FirebirdV6
Sep 29, 2002 10:47 PM
pardonme2711
Jul 21, 2002 12:40 AM
mult68
Mar 15, 2002 10:39 AM
