Request.
Car: 86 Trans Am
Engine: 355 soon ;)
Transmission: 700r4 w/Shift Kit
Request.
Can someone post up a outline of a 3rg gen Firebird. I'm in the middle of some ideas and want to sketch out some possable work but have had no luck finding a "coloring book" outline of a firebird.
top, side front 3/4 view, any would be very helpful. Thanks.
BTW: sorry my first post is a request.
<--86 trans am <--in the middle of a motor install
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Err.. I've got a half dozen outlines of firebirds from my sketching run on a concept a year ago... they're sitting on my dead hard drive
sorry..
Not that hard to make, though.. just grab a picture of a bird at an angle you like, open it up in MS paint, and start outlining the parts you need to remain static in black.. when you think you've got all the outlining done, convert it to 16 color, delete all the stuff you don't need (easy to do in 16 color by using the fill tool.. fill with a color you want to get rid of, then fill with white.. go back and forth for each color a few times and it should be a black/white image)
sorry..Not that hard to make, though.. just grab a picture of a bird at an angle you like, open it up in MS paint, and start outlining the parts you need to remain static in black.. when you think you've got all the outlining done, convert it to 16 color, delete all the stuff you don't need (easy to do in 16 color by using the fill tool.. fill with a color you want to get rid of, then fill with white.. go back and forth for each color a few times and it should be a black/white image)
tonys91rs
Oct 10, 2015 03:31 PM
