Suggestions
Car: '92 Heritage Z28 Convertible
Are you refering to part # SD360VTPI? Did you buy a SDPC engine? Do you like it?
I have been looking at crate engines and the SD360VTPI tops my list so far.
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
What are you looking to do? (Street driving, racing, a little of each?)
How much HP are you after?
What is your budget?
A rebuild is probably the cheapest and most risky way to go. Could be as little as $500.00
After that there are a lot of good crate engines available from Chevy. Starting at about $1100.
If you are after much more than about 350 HP, I would start to look at a custom built engine from a REPUTABLE builder. You could save a little money over a crate engine.
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
Car: Faster
Engine: Than
Transmission: You!
What ever you decide to do, make sure you put new injectors in it. I recommend the 24 # SVO's.
I can take care of the PROM / ECM tuning if you are interested.
Mike (1bad91Z)
Mike (1bad91Z)
darwinprice
17
Oct 11, 2015 11:51 PM
