South Central Region Board for the states of Texas, Oklahoma, and Louisana.
I need your old fuel injection stuff!
Old Sep 13, 2006 | 07:39 PM
esc's Avatar
esc
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
I'm looking for almost any kind of throttle body or TPI fiuel injection stuff.
Do you have the old TBI off of a 305, V6 or any GM vehicle?
Do you have an old wiring harness colecting dust (even if it is cut up)?
Old computer controlled (V8)distributors?
Stock in-tank fuel pump assembly?
Old factory sensors out of the junk (GM) motor rusting away in your back yard?
I need them all!
Almost any kind of TBI or TPI part could be usefull. I know some of you must have old stock stuff laying around that you will never use again. I need it!
I'm experimenting with whatever I can get my hands on. Your parts might end up on an off-road only rock crawler or a custom quad-double_barrel TBI. There is no telling, it all depends on what I can salvage from your garage.
Donations will be appreciated, or take a look at my big list of stuff (Eric's Swap Meet) as mentioned in the swap meet thread and see if you want to trade for anything.
Thanks,
Old Sep 13, 2006 | 10:01 PM
camaroboricua's Avatar
Car: 1990 Camaro RS
Engine: 355 c.u.
I have an old 305 TBI that i could probably steal some parts off of, like:
computer
wiring harness (missing a few wires, have to check on it though see if its still usable)
original distributor
oil press sensor
let me know if anything else comes up
Old Sep 14, 2006 | 06:42 AM
esc's Avatar
esc
Engine: 377
Transmission: 400
If your wiring harness is cut up and unusable...it is PERFECT for me!
I'm really just after the connectors.
I could use the distributor, especially if it is a divorced coil version.
Oil pressure sender? Why not...but I'm more looking for MAP, IAT, coolent temp..etc. Stuff that the injection relys on.
Old Sep 14, 2006 | 11:57 PM
Car: 1990 Camaro RS
Engine: 355 c.u.
darn! I was overthere working on the car and i forgot to take pictures of all the stuff! wheres the IAT and MAP sensor located at? its been too long since ive looked at this engine...Pm me and we can work something out for the vss and some of this stuff
jhawkeye
May 25, 2022 06:33 PM
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
86Base
Aug 13, 2015 05:06 PM
