South Central Region Board for the states of Texas, Oklahoma, and Louisana.
91 rs 383
Old Oct 16, 2007 | 03:58 PM
slo86z's Avatar
Car: 88&90 iroc z
Engine: 88 350 tpi/90 ?
91 rs 383
have you guys seen the 91 rs on craigslist?the guys selling it pretty cheap and has a 383. sale-449558924@craigslist.org
Old Oct 16, 2007 | 11:21 PM
kewl_blades's Avatar
Car: 2x1991 & 2000 Camaros
Engine: 350, 305 & LS1
Transmission: TH-700R4 and 4l60E
Re: 91 rs 383
Seems to be making the rounds...
http://houston.craigslist.org/pts/449558924.html
https://www.thirdgen.org/forums/sout...-rs-383-a.html
Old Oct 17, 2007 | 09:08 AM
aldixie's Avatar
Car: 1991 RS Camaro Convertible
Re: 91 rs 383
I bought it off of Estone, The engine needs a lot of hook up work and instead I'm going to put back in an emissions legal motor. I was going to use parts off of it to use on my vert as I have parted a couple in the past but its just in too clean condition to part. There are no power brakes as the intake does not have a vacuum take off and I have tried for a couple of days to get it idling but with no luck. If I sell the motor then I can put another back in it and get it painted.
Alex
Old Oct 17, 2007 | 12:50 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Re: 91 rs 383
I am glad you bought that car Al, because everyday I saw it on here I wanted it more and I have no where to put a new car. You can hook up your power brakes to the big vacuum port on the carb instead of the manifold. Thats how I run mine. If I would have bought the car i would have just ripped on of the entire top end and put in a more streatable cam with better heads and an RPM air gap intake. Since your selling the motor do you have the specs on it?
Old Oct 18, 2007 | 09:24 AM
aldixie's Avatar
Re: 91 rs 383
I did look on the carb to see if there was any other take off but there's not. But glad you reminded me about the manifold, I have an edelbrock performer sitting in the back of the garage that I completely forgot about. I may try fitting that. Still don't have any specs on the engine, if I pull it I'll take the pan off to have a look. I'm not in any hurry and if I get it running well I'll probabley keep the engine in the car. I do have a spare serpentine belt system with another PS pump and also all of the AC which I can put on it as well.
I'm going to put in new window lifts in the car this weekend as both of them are broken also have some 4th Gen front seats that I can put in it. So I'll be working on it.
Old Oct 18, 2007 | 11:57 AM
IROCaholic's Avatar
Car: 89 Camaro RS
Re: 91 rs 383
Nice! Sounds like your doing right man. You should bring that car to the meet.
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
