South Central Region Board for the states of Texas, Oklahoma, and Louisana.
New Crank. One quick question
Old Oct 7, 2009 | 06:47 PM
antsZRS's Avatar
Car: 1990 Camaro ZRS
Engine: 350 SBC
I just purchased a new eagle crank for my car. it is an internally balanced crankshaft. do i have to get it balanced since it has a neutral (0) balance?? and what does this mean?
Old Oct 7, 2009 | 07:10 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Re: New Crank. One quick question
You will have to balance the entire rotating assy.(rods,pistons,crank) for your engine. Just make sure your flywheel/flexplate and harmonic balancer is for internal balance.
http://www.carcraft.com/howto/ccrp_0...l_balance.html
Link for info.
Old Oct 7, 2009 | 07:11 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
i need to set up a time next friday to pick up that stuff from you
Old Oct 7, 2009 | 07:44 PM
antsZRS's Avatar
Engine: 350 SBC
i also hear that as long as i dont modify "it" i wouldnt have to balance it. what ever that means from eagles website. however the crank and bearing are all new. the rods and pistons are not. so i would still have to get the rods and pistons balanced to the new crank?
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
