Houston...2010 spring or summer meet?
Car: 92 Camaro T-5
Engine: tbi 305
Transmission: t-5
Axle/Gears: ?
Re: Houston...2010 spring or summer meet?
this damn rain sucks!!! an then the cold freezin weather , not alot poeple like goin out when its cold !!
Car: 82 Trans Am
Engine: 383
Axle/Gears: Built 4th gen 3.42 posi/disc
I need to adjust my valves but my 'delicate' fingers refuse to work in the cold.
On top of that, i'm sitting in my home office stinking up the place for lack of water to shower 'water main burst'.
Smile and be happy as spring is almost here!!!
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Thats funny...spring is almost here. Back in pittsburgh, winter hasnt begun yet!! (even tho we got pounded so far with snow) February is downright brutal most of the time...and last well into march and sometimes even some mild snow in april.
Car: 82 Trans Am
Engine: 383
Car: 92 Camaro T-5
Engine: tbi 305
Transmission: t-5
Axle/Gears: ?
what part of houston u live in ? ah live in the south east side of houston 45s and beltway 8
at least i will have enough time to get my few little things done before the meet. got the a/c delete finished. valve covers and aircleaner will be here soon. front speakers done. needs to warm up for some buffing and cleaning.
Car: 92 Camaro T-5
Engine: tbi 305
Transmission: t-5
Axle/Gears: ?
baby should be due in like two weeks so ah wont be able to fix up mah car but still with a 5.slow motor
Car: 82 Trans Am
Engine: 383
@one92rs
I too need to titty up the car with some cleaning and polishing. Unfortunately for me the car got bumped in the nose while in storage and now needs some paint work. Rest of the paint is not great but presentable.
Long term forecast shows sunshine for later next week... yippy!!!
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
hey lance what did you do with the compressor, lines and ac condenser you pulled off your ride when you did the ac delete? Did they work? I actually totally need those parts 100% like yesterday... unless you were keeping them... Hey Orr ... just wait pretty soon you will get your first taste of a Texas spring time .. currently... this is winter..
Car: 92 Camaro T-5
Engine: tbi 305
Transmission: t-5
Axle/Gears: ?
Am in SW Houston 'beltway 8 & 59'
@one92rs
@one92rs
Car: 82 Trans Am
Engine: 383
I look forward to a meet up for just this kind of reason 'networking'.
The paint is chipped right on the tip of the nose and although really minor, it is very visible and ugly. With your baby due soon i know your time will be valuable so, i will be happy to help where i can with your ride. I am by far no tuner but i can assemble/disassemble anything... lol
Car: 1991 Z28
Engine: 355 TPI
man i'm pretty good at tearing stuff apart as well. Although i'm kind of stuck in my own little hell so to speak...
Car: 82 Trans Am
Engine: 383
A little off topic but i just had to share. Guys when i built this 383 and dyno'd it, it ran like total crap 'with my tuning' but, i was able to squeeze 348.4 rwhp and 493.7 rwt. A good friend stopped by today and got her tuned better then i ever felt. I had total advance at 29 but now it is at 35 and feels like there may be more. My secondaries now feel like a 5th gear when i romp on it at 55. I never had a problem with low rpm as it would always get hairy with little effort while in 2nd or 3rd gear. Anyhow, today i also picked up a Holley 4160 '750 double pumper', so i will be replacing this Edelbrock 1411 '750 vacuum junk'. I also ordered a 1" Phenolic 'open' spacer for the added horsepower since i have the clearance.
Once i get this Holley setup, i will need to get her a dyno tune to get her 'really' dialed in. The place i went to last time SUCKED as they were no better with the carb/timing then i was. I'd hate to waste $75 for 3 pulls so i hope we can get a dyno day scheduled early this spring. If anyone has any recommendations where/who can do a GOOD carb/no-ecm dyno tune i would appreciate it.
Car: 89 Iroc-z
Transmission: TH400
Any place that has a wideband o2 sensor attached in the exhaust should beable to get an idea what the carb is doing for fuel, and make adjustments from there, as in jet up or down to get air fuel ratio in line
Car: 82 Trans Am
Engine: 383
GREAT idea. I hadn't even thought about doing it that way. I just may know someone too 'the inspection station'.
Car: 89 Iroc-z
Transmission: TH400
Every dyno place i've been to has a tail pipe attachment for wideband so hook it up and it should give you an idea.
Just remember if you have any leaks in the exhaust pipes from headers back, it may read leaner than it is due to extra o2 getting into the exhaust stream. Also tune it abit richer on the dyno than you want to run on the street. Street loads the motor more, so it will lean out on the street. I'd shoot for 12.4 to 1 air fuel on dyno, and it should be closer to 12.8 on the street
I got the trans am inspected saturday and it passed just fine, just needed wiper blades haha. Its a 99 LS1 with LS6 manifold/EGR delete, longtubes with AIR, catted y pipe and SLP Loudmouth 2. It passed since the codes were turned off in the ecm so no check engine lights.
Car: 82 Trans Am
Engine: 383
Sounds like a really nice ride. Thanks for the info to.
Car: 89 Iroc-z
Transmission: TH400
Its ok car... mechanically sound but its been "totaled" before. From texas it spun out and had front/rear body damage. Local shop in PA bought it to refurbish and resale. I got it for 5500 with new ebony leather seats, new bumpers, and ZR1 SS wheels. I put money in tires to get it road worthy, then bought the lid/filter for it. Then headers/intake/etc. Got the back bumper painted to match the car since it was off a different car. Paint could use buffed/wetsand. Has some scratches and paint peeling on headlight cover and some on hood, but for a 400hp daily driver LS1 trans am I always wanted I cant complain, especially for the price. Decent LS1 car for the price of a good quality thirdgen aint bad
Automatic/2.73 is nice for highway but I wish it was a 6 speed.
Car: 1991 Z28
Engine: 355 TPI
dude you should drop some pics of her up on here....
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Orr, you did get the VI30 form too, right?
Car: 89 Iroc-z
Transmission: TH400
I dont know what that is, is it the out of state form for registration? I got some form that I am suppose to take to a courthouse to get registered.
Car: 82 Trans Am
Engine: 383
It is needed when reg'ing an out of state car.
I was so looking forward to meet this weekend until one of my boys called and said he would be coming back from offshore this weekend and, there is something i learned a long time ago... 'NEVER pass up a chance to spend time with my sons'. So i will be in S.A. this weekend.
Car: '91 Formula
Transmission: TH350 built
Im getting back into my car, Im going to register it again. I don't know about insurance and Im going to have an inspection problem but Id like to come.
I need to do something with my son Max's 1990 Firebird 6 cyl. Remember it got wrecked a few years ago and it was declared totaled. We repaired it and it has a salvage title. Well it got wrecked again, hit in the front. He has been driving it since last summer with the hood tied down, but I just got him a different car. It needs a hood, bumber cover and honeycomb bumper piece and one new headlight. Maybe a few other pieces.
I could fix it for about $2000 but Im not sure what I could sell it for after that, maybe $2500, maybe I can just get $500 now with someone who wants to fix it, or even to a salvage yard.
If just turned over 80,000 original miles. The interior is good except the driver seat is ripped now in the normal places.
Any ideas??
Any ideas??
Car: 82 Trans Am
Engine: 383
Any ideas??
Any ideas??
Car: 89 Iroc-z
Transmission: TH400
It is a Certificate of Identification. Inspector verifies/documents your VIN#.
you probably have it then.
its green piece of paper with the VIN, mileage, your name, tag number and drivers license number on it.
most places will tell you that you need it when you get an out of state vehicle inspected.
Car: '91 Formula
Car: 89 Iroc-z
Transmission: TH400
LOL at you guys thinking this is cold weather. Need to go to pittsburgh in febuary when its -10 degree windchill with 20mph winds
Fun stuff
I'm rockin shorts and t-shirts this week
Fun stuffI'm rockin shorts and t-shirts this week
Car: '70 Bronco, '91 Firebird, '03 Chevy
Engine: roller 302, 350 TB, stock 6.0
Transmission: NP435 Granny 4 spd, 700R4, 4L80E
Axle/Gears: 4.56 spool, 2.73 open, 4.10 broken
Well yea, this is acceptable now, I had my AC on driving around yesterday. I usually exaggerate & say anything below 80 & I need a jacket, but this year, I guess because I put on some weight, I can deal with 60 or so fine. Below that & I just don't like it.
Car: 92 Camaro T-5
Engine: tbi 305
Transmission: t-5
Axle/Gears: ?
Car: 92 Camaro T-5
Engine: tbi 305
Transmission: t-5
Axle/Gears: ?
lol ah can handle it im 19 but most guys with cooler cars and beautiful cars ..dont like to go ! no offense to any older men !
Car: 89 Iroc-z
Transmission: TH400
If i had my turbo car i'd only drive it during december-january months...else its too hot for it and will over heat
uess we havent set a date yet. i keep doing little things to mine. got my valve covers in and they need a little ploishing. center bolt aluminum flamed covers. air cleaner will be in tomorrow. going to polish all of them with mothers billet polish. also going to order hose cover kits. hopefully there will be some good weather soon. looking to go to some local meets soon.
Car: 1991 Z28
Engine: 355 TPI
Never been a big fan of the hose cover kits myself... but to each his own... I'd love to get mine running again and throw some exhaust up on it and maybe redo the seats that are sitting outside the car.... Still worried that my motor aint turning though... I've got a couple more things to try before i get really worried or pissed... lol
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
I will try and make a meet once I know the date. Have been out of sync lately,as I was taking care of my wife who on Dec.31,2009 passed away due to ovarian cancer. Am trying to get my life and my head together,not an easy thing to deal with losing her as we have been together about 30 years. Have a lot of loose ends to tie up,the Camaro being low on my list. Larry
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
Larry, I'm so sorry to hear the news.
If there is anything at all I can do to help, please let me know.
Whether you need help moving furniture or just want an excuse to get out and take your mind off of things, or whatever, I'll be happy to help.
On a lighter subject: I expect to be out at my shop installing my Dual/Parallel Walbro 392 inline fuel pump setup on Saturday. If it doesn't rain I'll probably go out to Otto's afterwards.
i hate to hear that news Larry, my condolences
Car: 89 formula 350
Engine: 402 CI ls2 with tvs1900
Transmission: t56
I am sure the meet will be on a saturday afternoon like they have always been.
I am pretty sure Mike is going to make a meet post soon. Larry sorry for your loss, I can't imagine what your dealing with. prayers are with you...
ESC-- do you think its worth the drive out to ottos from freindswood?
thinking about going to otto's or keema this Saturday. anybody heard if keema is happening this time of year?
When the pearland home depot gets going again I will let everyone know, maybe we could all meet up there one friday night for a minni meet. the holidays and weather have kind of put a squash on pearland, I went about 2 or 3 weeks ago and there was only around 15 to 20 cars. I saw 92-t5 there early JAN...what up dude? are you having a baby soon? or was that someone else?
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
sorry guys but im back at school, ill be back mid may and i'm definitely in for some summer cruises
Engine: 377
Transmission: 400
Unless it is actually raining, I'll probably head over there as soon as I get my fuel pumps installed. I'm hoping for about 4:00.
Car: 92 Camaro T-5
Engine: tbi 305
Transmission: t-5
Axle/Gears: ?
When the pearland home depot gets going again I will let everyone know, maybe we could all meet up there one friday night for a minni meet. the holidays and weather have kind of put a squash on pearland, I went about 2 or 3 weeks ago and there was only around 15 to 20 cars. I saw 92-t5 there early JAN...what up dude? are you having a baby soon? or was that someone else?[/quote]
yup kevin im soon to be ah father .
little nervous lol babys due date is jan 25th but well see an im down to meet at the home depo at pearland on 518 tomorrow jan22, 2010 if anyone is down send me a PM see we could meet up !
, I am in Katy so I am close to you, if you need anything let me know
