South Central Region Board for the states of Texas, Oklahoma, and Louisana.
advice/help
Old Feb 6, 2010 | 01:30 PM
Transam.82's Avatar
Car: '82 Trans Am
Engine: 388 5.7L V8
Transmission: T-10
advice/help
I had a tranny swap on my car to a T5, and now I pretty much don't accelerat after 3000rpms in 1st, 2nd and 3ed gear. Someone said it might be that my rear-end gears are wrong size. Could that be or is it the tranny??
Old Feb 6, 2010 | 02:51 PM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
Re: advice/help
did you replace the clutch? might it be slipping?
Old Feb 6, 2010 | 06:38 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: advice/help
is the clutch and pressure plate new? Was the flywheel re surfaced?
Old Feb 6, 2010 | 07:53 PM
Transam.82's Avatar
Car: '82 Trans Am
Engine: 388 5.7L V8
Transmission: T-10
Re: advice/help
The clutch and flywheel were replaced, I don't know about the pressure plate. Though I would assume so, everything between the tranny and engine was replaced.
Old Feb 8, 2010 | 12:47 PM
Transam.82's Avatar
Car: '82 Trans Am
Engine: 388 5.7L V8
Transmission: T-10
Re: advice/help
Its like something isn't connecting to the engine/tranny after 3000rpms, because the engine gets louder and the rpms go up, but the car is cruising, or barely accelerating.
Old Feb 8, 2010 | 06:11 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
Re: advice/help
sounds to me like the pressure plate
Warnd
May 30, 2025 10:00 AM
blkjck
Mar 10, 2014 06:30 PM
89Iroc_vert
Jan 29, 2014 05:23 PM
LedZep
Oct 13, 2013 08:48 AM
88Zfor_me
Feb 20, 2013 10:17 AM
