Need a Transmission
Car: 1992 Camaro (Z28 Clone)
Engine: LB9|TPI
Need a Transmission
Anyone in the houston area know where I can get one for less than 1k?
Is that even possible?
Engine: LB9|TPI
Re: Need a Transmission
R&R?
The transmission works fine from what I know.
Im swapping in a v6 and the trannys are not compatible so that leaves me with having to a get a new one.
My bad should have added that detail
EDIT: Swapping out the V6 for a v8
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
Remove and replace*
Swapping out for v6?
Put a tree fiddy in it
Engine: LB9|TPI
Still contemplating what to swap in definitely not going to be a v6 though...
The ultimate goal is a turbo 350
and me and my bro will R&Ring it....
Engine: LB9|TPI
Car: 90' Firebird Formula 350
Crack open a summit or jegs, if you are willing to spend $1000 dollars for one, then it opens up some choices for you.
If you are like most of us, your dollars are precious, and you can get one for less than that. LKQ junkyards have 50% off on holidays, and you could get one dirt cheap from them, pay to have it rebuilt if necessary, and probably still be in it for less than 1k.
Engine: LB9|TPI
I definitely in the category of broke 17 year old lol Ill look into that when I have a chance to right now I have not even decided what engine I will be going with
Engine: LB9|TPI
So if i was to go to an lkq and find a thirdgen with a transmission, how can I tell if it is a good transmission?
Does it have to be from a thirdgen?
Engine: LB9|TPI
Also thinking I want to go with a carbed l31 and leaving it stock with the exception of a full exhaust.
It would be the cheapest way to get a good 350 and it would still leave me open to getting more HP out of it later on..
Car: 02 SS
i may be having a 350 for sale here soon if ur interested
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
Engine: LB9|TPI
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
